Simulating Intersymbol Interference on channels
  • Thread starter Thread starter maverick280857
    Interference
The discussion centers on simulating a channel affected by intersymbol interference (ISI) using a Bayesian metric for maximum likelihood sequence detection with the Viterbi algorithm. The original poster seeks guidance on implementing this in MATLAB and calculating the bit error rate based on the provided metric. Participants mention ongoing efforts to clean up old threads for better accessibility and reference for future readers. Technical insights and resources for simulation methods are requested to aid in solving the posed problem. The conversation emphasizes the need for clarity and technical commentary to support the original inquiry.
maverick280857
Hi
I'd appreciate help with the following problem:
Suppose I have a Bayesian metric for navigating a trellis to detect the maximum likelihood sequence on a channel corrupted by ISI. The usual Viterbi algorithm works on the usual ML (nonstochastic channel) metric. Now, given the expression for this metric, how can I use MATLAB to simulate the channel? What is the approach to solve such a problem?
Any pointers to existing books or papers on elementary simulation methods would be appreciated too.
Thanks in advance.
EDIT: Given the expression for the metric, how do I find the bit error rate?
ping @jedishrfu Do you know what he's talking about? Spring clean.
The jedi is in. What's up here?
Greg initiated an old threads cleanup a few months ago and Wrichik and others have been at work cleaning up or deleting the old threads. Basically we add more commentary or references to help future readers who may stumble upon the thread during a google search.
Yes, this thread is one of those spring cleaning workshop ones. I was hoping you could comment technically on the OP's question.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
