Simultaneity and the Twin Paradox
138 replies · 12K views
Dale said:
I have to admit that my feeling is somewhat in between. The triplet version is physically and mathematically fine, but in my opinion is loses all of the paradoxical character.
The purpose of logical, physical or mathematically analysis is to cut through the false paradoxical character. Losing the paradoxical character is precisely the point.
Dale said:
So the triplet version is mathematically and physically fine, but IMO it misses the point since it loses even the false symmetry of the traditional twin paradox.
I see what you're getting at. The "paradox" is supposed to make the student think about their own (mis)conceptions about time in relativity, and the single traveling twin is harder to dismiss as some physics professor trick question than the two clock relay.
But I think the non-accelerating version is very useful in understanding that it's not the acceleration that's the problem - it's carelessness when stitching reference frames. It shows that you can have exactly the same situation with no acceleration.
MikeGomez said:
No acceleration would mean no age differential.
It's possible to set up a twin paradox situation with no acceleration: do both clock comparisons as the twins pass one another, use a hyperbolic orbit around a distant star to do the turnaround. It's still a special relativity problem (more precisely, the general relativistic corrections are negligible) if the trip is long enough. This version has the intriguing property that if the two spaceships have no windows or other way of checking one's relative velocity, both twins will have completely symmetrical experiences: they synchronize their wristwatches while floating in freefall in a windowless box; nothing interesting happens for a while; then they compare wristwatches and find less time has passed for one than the other.
While the traditional version of the twin paradox works by losing the distinction between "frame" and "inertial frame", this one works by losing the distinction between "inertial frame" and "local inertial frame".
The main pedagogical value is that it shows that the acceleration in the traditional version is something of a red herring. The essential thing is the proper time along a path through spacetime; acceleration is just an inevitable side effect of trying to construct a situation in which objects take different paths between the same two points in a flat spacetime.
I guess that I see the purpose as slightly different. To me, the student has internalized an incorrect rule "all reference frames are equivalent", and the purpose of the twin paradox is to replace that incorrect rule with the correct rule "all inertial reference frames are equivalent". Particularly with the usual observer-centric terminology, I don't think that the triplet paradox confronts the incorrect rule in most student's minds and I think that directly confronting the incorrect rule is essential for replacing it. I believe that a student who has internalized the incorrect rule will still retain that rule even after analyzing the triplet paradox.
Yes, that's a good point. On the other hand, the issue with not confronting the acceleration is that:
The student has internalised the rule: "the twin who accelerated is really time dilated". And, therefore, "not all inertial reference frames are equivalent": in the sense that an inertial reference frame that results from a period of acceleration is fundamentally different from an inertial frame that (during the course of an experiment) is not the result of an acceleration phase.
If anything, I'd say this latter misconception is more difficult to shake.
Anecdotally, that's been my experience as well.
Yes, that is a good point. That is a particularly difficult one because it goes along with their earthbound preconceived notion that the reference frame of the ground is special, which is probably a notion that they have held most of their life so it is very "sticky".
I think that can be avoided by a careful presentation. The teacher needs to be explicit about the incorrect rule and the correct rule, using the twins paradox as an example. Also, the teacher should teach the difference between inertial and non-inertial frames before teaching relativity.
More precisely, if both observers start out at rest with respect to each other, and neither one accelerates, there will be no age differential.
In flat spacetime, if the observers are in relative motion and neither one accelerates, "age differential" is not well-defined because they will only meet once.
In curved spacetime, it is possible for two observers in relative motion to both be in free fall and meet multiple times. And in general, in such cases, there will be an age differential.
Yes.
Just curious. Does this also lose the distinction between proper acceleration and coordinate acceleration?
I think of it in a contrary manner to that, i.e. the fact that two clocks in flat-space initially at rest with respect to each in an inertial frame requires acceleration (in one form or another) in order to achieve age differential, is a profound concept worthy of careful consideration, and not a red herring or just an inevitable side effect.
This seems like a bias for explaining the twin paradox purely in terms of time dilation due to uniform velocity. The 3-clock scenario accomplishes this. The stay at home twin synchronizes his clock with a passing outbound clock, an inbound clock is synchronized with the outbound clock some distance away, and the inbound clock is compared to the stay at home clock which shows more time has passed, i.e. age differential with no acceleration. Then piggybacking this 3-clock scenario to the twin paradox where the two twins start at rest relative to each other, it is said that the time dilation due to acceleration (gravitational time dilation) is negligible.
Although that may be true, I could have the opposite bias and instead of negligible time dilation due to acceleration, I could specify in the thought experiment negligible time dilation due to uniform relative velocity. The traveling twin could travel with great acceleration the entire trip, completely absent of any periods of coasting.
In that case, all the time dilation is due to the relative velocity; it is not directly related to the magnitude of the acceleration.
You can have a scenario where the stay-at-home twin moves in a circle with the same magnitude of proper acceleration as the traveling twin throughout. If the circle is small and the velocity relative to the original inertial frame is small, then there would still be approximately the same differential ageing.
(Or, back and forward, mimicking the traveling twin's magnitude of acceleration, but never getting to a significant velocity relative to the Earth.)
Proper time is the length of a spacetime path. Period.
Of course not. It's just that there's more than one way to change direction, some involving proper acceleration and some not.
Edit: In fact, I'd go as far as to say that even asking this question is a hint that your "acceleration matters" approach is back-to-front.
No, two clocks initially at rest require acceleration to achieve non-zero relative velocity. They require more acceleration to meet up again. But the age differential is a result of their paths, not their acceleration. Focussing on the acceleration is like focussing on the details of why I drew a kink in a line (which therefore crosses a straight line twice, forming a triangle) and trying to understand the triangle inequality from that.
Acceleration is important. Lines without corners do not cross more than once in flat spaces. But focusing on why they have a corner isn't really relevant to understanding why two sides together are longer than one.
This cannot be correct since you cannot explain the twin paradox in those terms. You need the relativity of simultaneity as well to resolve the paradox.
How? The time dilation formula depends on velocity. How are you going to remove this dependence? You can stop having uniform relative velocity, sure, but that doesn't change anything about the argument.
By switching to constant acceleration you simply switch from a triangle to a smoother shape. You don't remove the differential ageing (due to the different intervals along the paths), you don't remove its dependence on relative velocity, and you don't remove the problems with the relativity of simultaneity. You just smear the latter two out over the whole path, making the problem intractable without calculus.
Apparently I have confused being in different gravitational potentials with change of gravitational potential. Thanks for clearing that up.
Wow, I leave for a while and a lot of interesting discussion has filled my thread!
I disagree with PeterDonis about the video mapping and the results I expect. I suspect Peter has some other mapping in mind, and we are talking at cross-purposes, but really, it’s not worth pursuing. Let me re-focus on a simpler thought experiment.
There are two very precise clocks: A and B.
Clock B is accelerated (relative to A) until it is moving at constant speed v toward A. As B passes by A, both clocks synchronize to 0 and begin counting. In terms of the Lorentz transform, this is where reference frames coincide exactly and (x, y, z, t) = (x’, y’, z’, t’) = (0, 0, 0, 0).
At time t on clock A, A fires a pulse of light at B. When B receives the pulse, it stops counting. We can now decelerate B to inspect the time on the clock.
I have two questions:
  • If I run the experiment a hundred times using the same procedure, same t and same v, will B always display the same number? If yes, proceed to the next question. If no, stop here. A hint at why would be interesting.
  • Given the parameters of the experiment as described here, the value of v, and the reading on clock B, would a competent physicist be able to calculate the time t at which clock A fired its pulse? This is not a theoretical number; it is the time clock A used to trigger the firing of the pulse. If yes, we’re done. If no, a hint as to why would again be nice.
The reverse of the second question might also be interesting. Given t and v, could one calculate the end time on B? Note: the difficulty of the calculation is immaterial, but it needs to be possible.
Yes. (I'm not sure why a "no" answer would even be considered possible, since relativity is a deterministic theory.)
Yes.
Yes.
None of these calculations would be at all difficult for a competent physicist with knowledge of relativity. (I am assuming that the experiments are all to be done far out in empty space, far away from all gravitating bodies, so that spacetime can be assumed to be flat in the region used for the experiments.)
It's possible that I'm misunderstanding the mapping you have in mind or what you are trying to do with it. My biggest concern with what I understand you to be trying to do with the video is what I said in post #55.
OK, from post #55:
PeterDonis said:
But you are trying to construct a video in which A's clock ticks slower than the B/C clock, as if that somehow "truly" represents "what is happening at A". That can't possibly be correct.
And yet, that's exactly the bill of goods a lot of sites seem to be selling, including Michael Weiss on the web page that Nugatory pointed me to way back in post #2. Michael Weiss says: "Now different inertial reference frames have different notions of simultaneity. The Outbound reference frame says: "At the same time that Stella makes her turnaround, Terence's clock reads about two months." The Inbound reference frame says: "At the same time that Stella makes her turnaround, Terence's clock reads about 13 years and 10 months." The apparent "gap" is just an accounting error, caused by switching from one frame to another."
So Michael Weiss makes claims of simultaneity for each reference frame and he claims a very specific correspondence (from the viewpoint of that frame, of course). When I say the same thing, I get all sorts of crap about there being alternate ways to draw simultaneity planes or that simultaneity doesn't actually mean anything. Well, perhaps at some rarefied physics level, that's true, but at the level of the tutorials I'm reading, people seem totally willing to assign a precise meaning (and value) to simultaneity (again from a single reference frame).
The thought experiment I posted pokes at exactly that concept: if the clock experiment always gives the same answer and if t is calculable, then it implies a precise and real-world meaning of simultaneity that matches real-world numbers. There may be other curiosities for advanced physicists, but I don't need to go there right now.
For each inertial frame, meaning the one in which the outbound traveler (B in your scenario) and the inbound traveler (C in your scenario) are at rest. In other words, he is using a particular specific definition of simultaneity, the one that goes with global inertial frames in flat spacetime.
But you'll notice what he doesn't say: he doesn't say that there is a single frame in which the traveler is always at rest. Nor does he say that any inertial frame's notion of simultaneity is absolute. Nor does he say that the "at the same time" calculations according to any inertial frame are the "true" representation of what is happening to the stay at home twin (Terence in his version, A in yours).
In fact, what Weiss is doing on that page is not telling you "how it really is". He is explaining the limitations of any viewpoint that treats the simultaneity of any specific inertial frame as absolute or "real". For example, that switching frames in mid-trip makes it seem like there's a "gap" in what is happening at A, when in fact the gap is just an artifact of switching frames.
But you're not saying the same thing as Weiss. That's the whole point. You are trying, or at least you certainly seem to be trying, to treat the simultaneity convention of a particular frame as absolute or "real". And it isn't. It's just a convention. If it were absolute or "real", then Weiss's dismissal of the apparent gap as "just an accounting error" would make no sense.
It implies no such thing. Every quantity you talk about in that experiment is an invariant, and can be calculated without even using frames of reference or assuming any simultaneity convention at all. It says nothing at all about simultaneity and certainly does not give any "real-world meaning" of it.
There's a trap for the unwary here.
A does not do anything at time t. He can't, because coordinate time isn't a real thing, just a convention. What he actually does is send a signal when his ship's clock shows a time he interprets as meaning he's reached the event we've agreed to call t. We deliberately picked the coordinate time in A's rest frame to be the same as A's clock readings, but that doesn't mean that the coordinates and the clock readings are the same thing: A can always choose to accelerate, or maybe never zeroed his clock and just adds the appropriate offset whenever he has to talk to anyone else about time coordinates.
I can calculate the coordinate time, t, at which the light pulse was emitted. I can also calculate the coordinate time t' at which the pulse was emitted. Neither of these are what A uses to trigger his pulse. He uses his ship's clock, which measures his time but does not imply any simultaneity criterion anywhere else.
If he posted here we would probably mention that simultaneity doesn’t mean anything, but the reason that we use him as a reference and you get all sorts of crap is that you didn’t say the same thing. He very carefully specified the frame and the quantity using standard language in a way to convey a unique meaning.
What happens with you and most relativity initiates is actually quite unavoidable. You don’t yet know enough to properly frame your question, so you include lots of irrelevant details and exclude some key relevant details. The result is that the question as written is ambiguous or unanswerable.
Respondents have two choices, either we can answer a different question, or we can try to get you to improve your question. If we answer a different question then there is the impression that we are being evasive. If we try to get you to improve your question then there is the impression that we are giving you crap.
I don’t know a way to avoid one of those outcomes.
Maybe should have posted these videos earlier. Watch in HD, read the explanatory text, and watch all the clocks all the time. BTW Mr Tomkins is an early and misguided attempt to describe what you see, the linked videos include light delay.
Hey, Dale, my phrasing was poor and I actually didn't mean it in a mean way (to clarify: I didn't believe you guys were being mean). Don't worry about it—you can continue to give me crap. :-)
Well, I tried to make sure my frames (inertial frames at that) were carefully specified. I'll admit to using simultaneous where Weiss uses at the same time. These sound equivalent to my ear.
The puzzle is that I can create what looks like an at-the-same-time correspondence between an event in A's and B's frame. B receives a video from A and calculates when the video was sent. The time the video was received and the calculated time it was sent are all from B's inertial frame of reference. The contents of the video establish what looks to me like a non-theoretical correspondence of B to A. I have never claimed that A would agree with any of this only that this is B's view of an at-the-same-time mapping.
Nor am I worried about a gap in the A, B, C scenario. B and C could both record the entire 10 year transmission from A. They would each have a mapping of the entire sequence and their mappings would be different, agreeing only when they meet at M. Splicing the videos together would clearly be artificial and only to show the point that we are changing reference frames.
Again, there might be some hair-splitting distinction as to whether a correspondence established by this method has any "real" meaning. If it is reproducible and repeatable, I can live with it. I am perfectly fine with the idea that someone in a different frame might completely disagree; I tried to make sure I always said that the correspondence was in one inertial frame and went one way only.
Interesting. Now my unwary response would that if A accelerates, we have stepped out of my experiment into a different one. And if clock time and coordinate time can't be said to have any real-world correspondence, then I would hate to planning the next space mission to some distant rock. I'm OK with the clock being "close enough" to the perfection of coordinate time. If the answer is within so many significant digits, I can live with it. Same for the at-the-same-time correspondence. This all seems like nit-picking: even if we can't build a perfect clock, it seems like a big jump to claim that there is no good-enough correspondence. And, in a thought-experiment, I can have a clock that perfectly matches coordinate time.
Oh, I meant to add that , if it seems we are in an infinite-loop here, it's OK to close this thread. My feelings won't be hurt. There are some concepts that are best left for a face-to-face discussion and I do have that neighbor who is a retired physics instructor and a pretty nice guy (he's been out of town for a while, which is why I haven't brought him into the picture just yet).
I didn't want to end the discussion if someone else felt strongly about responding. I'll leave that up to you guys.
Coordinate time is the time on a set of imaginary clocks. You can easily work out what one of those imaginary clocks would read, but they're imaginary. You can't use them for anything.
It's like latitude and longitude coordinates on Earth. There are no actual lines you can use to navigate. But you can use your compass and your sextant and what have you to take measurements and work out which latitude and longitude line would be beneath your feet if there were any.
Coordinates are incredibly useful to plan and communicate. But they're not real things, even when the imaginary clocks we imagine specifying coordinate time happen to tick (or we imagine them ticking) at the same rate as your clock.
It's that distinction between the imaginary coordinate clocks and the real clocks we use to keep track of how we imagine the imaginary clocks to work that is the trap I was trying to warn of. The Lorentz transforms relate one set of imaginary clocks and rulers at rest with respect to each other to another set of imaginary clocks and rulers all moving at constant velocity with respect to the first lot. The relationship between those imaginary clocks and rulers and your own measurement apparatus is well defined, so you can work out the readings they give when a particular coordinate time is T. But you aren't reacting to the coordinates - you are reacting to your measurements.
So sure I can calculate t and t'. But neither of those things is (directly) what A used to time his signal.
Let me see if I can paraphrase some useful content out of this. I send a real person on a real spaceship to a real location, transmitting video the whole way. All of this is real, but when we take the video and adjust frames for light delay, we have shifted out of the real and into the imaginary. While I can appreciate that the resultant calculations might not be perfect, they won't exactly be random numbers nor will they lack some connection to the real world.
So your point is correct, but the distinction is not that interesting to an engineer. Close enough is good enough for me. :-)
You are completely missing the point. It is not about precision. I can build a clock that keeps time to whatever degree of precision I want. However, when I try to subtract out the light speed delay from looking at that clock I have to make a decision about which definition of distance and time I use - the one associated with this set of imaginary clocks, or the one associated with that set of imaginary clocks. Once I've made that decision I can make calculations with any degree of precision I like. That does not invalidate someone choosing the other set of clocks. There is no "correct choice". I can switch between choices using Lorentz transforms.
Choosing coordinates is like choosing how to draw a map. I can choose to have north pointing up the page, or off at 45°. That will change my opinion about what "at the same height on the page" means in practical terms. It has absolutely nothing to do with the precision of my measurements. Similarly, I can choose to have one set of clocks at rest and decide "simultaneous" means one thing, or choose to have a different set of clocks at rest and decide "simultaneous" means something else. It has nothing to do with the precision of my measurements.
There is no randomness here (or in practical terms, experimental error can be tightly controlled). There is an arbitrary decision about which plane in spacetime you are calling "now".
I understand, I am just saying that your feeling is justified. We are in fact giving you crap, but I don’t know anything else we could do other than be evasive.
Me too. Also, “instantaneous” would be the same.
You did describe A, B, and C’s frames well, and I don’t think that caused any crap to be given. Where we ran into ambiguities is in your description of the correction process. For instance, you said A would do the correction so I assumed he would use his frame, but you had intended him to use another frame. And in the description of the correction process you used a simultaneous word without specifying which frame.
Events are not in a specific frame. They are in all frames. They merely have different coordinates in different times.
Sure. The whole point of the Lorentz transform is that it describes that correspondence quantitatively.
I am with you on this. I never worry about the “real” or not distinction. I simply identify it as frame-variant. If it is measurable, then I am fine with using it even if it is frame variant or require using some other convention.
Sorry, more imprecise language. I agree with you. I'm afraid to re-phrase it, but may something like "an at-the-same-time correspondence between a time in which an event occurred in A's and occurred in B's frame and from B's point of view." This might still sound like the event occurred in A--I do mean that the event occurred, period. The time is the only thing that I am establishing a correspondence with.
Yes, that is the purpose of the Lorentz transform.
To be clear about the answers I gave, I interpreted ##t## to be the time on A's clock, not a coordinate time. The time on A's clock when he emits the light pulse towards B is the necessary input to the problem.
And this appears to be what @Freixas intended, since his own problem statement says:
