Questions About Single Element Set X={0} in Euclidean Metric
  • Thread starter Thread starter anjana.rafta
    Element Set
The discussion centers on the properties of the single element set X={0} within different metric spaces. It clarifies that the nature of the metric space does matter, as it influences whether a set is considered open or closed. Specifically, {0} is both open and closed when treated as its own metric space, but only closed when viewed as a subset of the real numbers. In a discrete metric on [0,1], both {0} and {1} are also classified as open and closed. The conversation highlights the importance of understanding metric spaces and topologies for determining set properties.
anjana.rafta
i have few doubt regarding a single element set. let X={0}, in euclidiean metric. my questions are:
1. does matric space even matters? or matric space is defined?
2. is this set open/closed/none of them?
3. for a discrete matric on [0,1], [0,1]= {0}+(0,1] = {0}+(0,1)+{1}, then {0},{1} are open or closed?
how do we say that every element in dicrete matric space is open??
Thanks
I have a hard time figuring out what you mean with this. Why would a metric not matter?
If you consider {0} as a metric space, then this is open and closed. However, if you conside {0} as a subset of the metric space (\mathbb{R},d), then the set is closed and not open. As you see, open and closedness are relative depending on what the underlying set is.
If you consider [0,1] with the discrete metric, then {0} and {1} are both open and closed. In fact, EVERY set in the discrete metric is both open and closed.
Hope that helped!
PS: it's metric, and not matric :smile:
thanks for that quick reply. but am still confused.
1.does metric space even matters? or metric space is defined? this is wrt X={0}. this set be defined with any metric space.. does it matter?
2.If you consider {0} as a metric space, then this is open and closed. However, if you conside {0} as a subset of the metric space LaTeX Code: (\\mathbb{R},d) , then the set is closed and not open. As you see, open and closedness are relative depending on what the underlying set is.
am not able understand what tou stated in above comment
i think i havn't got the concept correctly. could you please point me to some place/book that talks about it. am a beginner with the course.
thanks for the PS :)
I am not sure where the confusion lies. However for starters, you can have sets with no metric but with a topology. You can also have sets with no topology.
Note: having a topology means open sets are defined and obey standard rules. All unions of open sets are open, all intersections of a finite number of open sets are open, the whole set and the empty set are open.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
