Single-phase full-bridge inverter with multiple pulse width modulation
The discussion centers on the design and waveform analysis of a single-phase full-bridge inverter using multiple pulse width modulation techniques. The user seeks verification of their logic regarding the current waveforms through the four thyristors and diodes, assuming ideal conditions. They describe the operation during positive and negative cycles, noting the complexity introduced by the reactive load. Concerns are raised about the behavior of the thyristors when attempting to turn them on with reverse polarity and the need for effective gate drive signals. The conversation highlights the importance of understanding load voltage and the role of flywheeling diodes in the circuit.
sandy.bridge
Hey guys. I have been theoretically playing around with a single phase full bridge inverter. What I wanted to do was determine the waveforms for the current going through each of the components (ie. the four diodes and the four thyristors). I assumed all of them were ideal. Since I have no idea how to simulate this, I was hoping someone here could verify if I have the correct logic in regards to my waveforms.
For the positive ON cycles, thyristors Q1 and Q3 are on. For the negative OFF cycles, thyristors Q2 and Q4 are on. The antiparallel diodes are there due to reactive load.
The reason I am unsure of my waveforms is I have only dealt with output cycles that go from positive to negative, then positive to negative, etc. This cycle goes positive positive positive negative negative negative, in regards to its polarity.
Obviously the minimum/maximum values will depend on the values of the circuitry.
Thanks in advance!
That looks about what I'd expect, except ... :smile:
during the moment when the load has its current reversed.
At that moment things will be a bit more apoplectic than you show, though I'm not sure what to expect, exactly --- you are trying to turn the thyristors on while they have reverse polarity. Are you going to use unusual gate drive signals to handle this?
You are exemplifying a load with significant inductance, perhaps you could have a go at sketching the load voltage, too? :wink:
I'd expect a web search would be turn up a good discussion of this. http://imageshack.us/a/img811/5412/thgooglefriend1.gif
BTW, I notice you adroitly avoided showing how you intend turning off those thyristors at the end of each pulse.
"flywheeling" diodes is an apt name
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 18 ·
9K
