B Single phase induction motor Torque under increased frequency and Same Current
Increasing the supply frequency of a single-phase induction motor to 500 Hz while maintaining the same current does not increase torque, as torque is dependent on current and flux. The relationship indicates that with higher frequency, the flux decreases, necessitating higher voltage to maintain performance. Although power output could theoretically increase with frequency, practical limitations arise, such as rotor and bearing design constraints, which could lead to mechanical failure. Simple simulations can help explore these scenarios, with various software options available for modeling motor behavior, including both analytical and finite element methods. Understanding these dynamics is crucial for safe and effective motor operation at higher frequencies.
StoyanNikolov
TL;DR Summary
Single phase induction motor Torque under increased frequency and Same/Constant current.
Hi ,
Consider Single phase induction motor.
What will be torque of induction motor, if we increase supply frequency 10 times, if the motor uses same supply current.
Let's say Torque (Supply frequency 50 Hz, Supply current 10 Amperes ) = N
What is Torque (Supply frequency 500 Hz, Supply current 10 Amps) = ?
Will it be 10*N ?
Also what will be the Output Power?
Let's say Power (Supply frequency 50 Hz, Supply current 10 Amperes ) = NWhat is Power(Supply frequency 500 Hz, Supply current 10 Amps) = ?
Thank you.
Same current = same torque.
Ten times frequency = 10 X RPM.
10 X RPM * same torque = 10 X power.
But you will need 10 X the voltage to get that much current at that frequency. The rotor and bearings are normally not designed for that speed, so it could self destruct due to rotor hitting stator at critical speed or bearing failure or rotor exploding or stator windings shorting or cooling fan exploding or ....
Likes alivakilian, russ_watters and DaveE
Thank you for Reply. It is idealised situation .
No friction.
No Eddy current losses.
So Torque doesn't increase if we increase supply frequency, when motor uses same current.
The torque is related to I*ø . With higher frequency, the flux will be reduced and you have to maintain it with the voltage .
Simple simulation can help to try different scenarios. Is there any easy to use simulator for electrical motors?
Likes Sarawestern
There are a lots of software you can use to model motors. Some of them using Finite Element Method and some just use the analytical models. Of course the analytical models are faster, but FEM results are more accurate and trustable. According to my own experience, I used EMWorks software. I think it has both simulation models and you can Choose to use FEM or not. search them on net and you will find useful videos as tutorials to start.
