Skateboardings physical limitations
  • Thread starter Thread starter skateboarder
    Physical
The discussion revolves around the physics of skateboarding, particularly focusing on the impressive stunts performed by Aaron Homoki. Participants explore the maximum height, speed, and distance a skateboarder can achieve while still landing safely, noting that skill plays a crucial role due to numerous variables. It is highlighted that landing on a skateboard can reduce injury risk compared to landing directly on feet, but the impact still poses significant risks. Concerns are raised about the long-term physical repercussions for athletes like Homoki, drawing parallels to the wear and tear experienced by extreme sports participants. Overall, the conversation emphasizes the balance between skill, physics, and the potential for injury in skateboarding.
skateboarder
Hey guys, first post so be gentle. Just thought I would share this short skateboarding clip. Very impressive stunts done by Aaron Homoki (yes it's all real). I would be very curious to see what the physics community thinks about it.
Is there a way to work out the maximum height/speed/distance a skateboarder can jump/fall from and still roll away without falling?
Also what do you think the repercussions of putting your body through these high impact situations will be later in Aaron's life?
Thanks in advance and enjoy the clip :)
youtube.com/watch?v=U2TzBJGViM4
(0:29 and 0:47 are the most interesting ones)
Welcome to PF.
Overview: physics of skateboarding.
Yes ... however there are so many variables that in practice it comes down to skill ... the boarder risks greater injuries with greater heights and speeds of course.
Aaon can expect the kinds of wear and tear most extreme sportsmen get. It's Achilles' choice.
Unlike landing on your feet, landing on a skateboard preserves your horizontal velocity, so it involves less shear forces, which often cause the injury in jumps. But it is comparable to a clean vertical fall from the same height. You need long & strong legs as dampers.
It's comparable to ski jumping or downhill skiing. Maybe there is some statistics online on joint wear in those athletes. Obviously, a single unlucky jump can cause permanent damage too, especially without protective gear.
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
