Small Circular Acceleratioon Question
  • Thread starter Thread starter LadyMario
    Circular
A wheel with a radius of 0.50 m rotates at 15 revolutions per second, prompting a question about calculating the acceleration at its outer rim. The discussion centers on the distinction between tangential and radial acceleration, with participants clarifying that the provided answer of 4.4x10^3 m/s² pertains to radial acceleration. There is confusion regarding the use of frequency to determine velocity, with suggestions to use the period equation T = 1/f to find the time for one revolution. Participants emphasize the need to distinguish between tangential and radial acceleration formulas, ultimately confirming that the focus should be on radial acceleration for this problem. The conversation highlights the importance of understanding angular motion concepts in solving such physics problems.
LadyMario
A wheel of 0.50 m radius rotates at 15 rev/s. What is the acceleration at its outer rim in m/s2
They want tangential acceleration right? Is there anyway to solve this without angular velocity/speed as we haven't learned that yet. This is part of the practice questions for my midterm on Work/Energy and Kinematics, so I'm looking for one of those methods to solve it.
The answer is 4.4x103 m/s2 but I can't seem to get that. Help?
What did you get and how did you get it?
I was using T=2piR/V to get V and then using that in a=V^2/R but a friend pointed out the 15 rev/s is frequency, and so I'm not sure of an equation for that.
T = 1/f. If the frequency is 15 revolutions/s, how many seconds would it take for 1 revolution? Your formula for acceleration is for radial acceleration, not tangential. Since the answer is non-zero, question refers to radial.
Yes I get that frequency means it will be 1/15 but what equation can I use to get tangential?
atangential = dV/dt.
oh okay. I was thinking about how to get that equation, how do I get time and velocity though? From the Period equation: T=2piR/V but this time T= 1/15 and solve for V?
Not sure if you are on the right track per your tangential acceleration inquiry. V can be found from the period equation. You are looking for aradial.
