Can You Create a Smoke Ring Using Only Air in Cold Weather?
  • Thread starter Thread starter kompabt
    Air Ring Smoke
A "smoke" ring can be created using only air in cold conditions by utilizing the water vapor in exhaled breath, which condenses into a visible mist. This mist can be shaped into a ring using the same technique as with tobacco smoke. Many individuals in colder climates have experimented with this method, achieving varying degrees of success. The process involves a "popping" technique similar to that used for traditional smoke rings. Overall, it is possible to create a ring effect without actual smoke.
kompabt
"smoke" ring with only air?
Can "smoke" ring be blown with only air (withouth smoke) in cold?
Yes. The water vapor in your exhalation will condense into visible "mist". This mist can be formed into a "ring" with the same "popping" procedure that you use to make a ring with tobacco smoke.
Almost everyone who lives in cold climates has tried this--some with more success than others.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
