Snell's Law HELP TEST TOMMOROW
Snell's Law is expressed as n1(sin)theta1 = n2(sin)theta2, where n1 and n2 are the indices of refraction for different media. To find the angle of refraction, the inverse sine function (sin-1) is used to isolate the angle after rearranging the equation. For example, when light passes from glass (n=1.51) to an unknown medium with an angle of incidence of 40 degrees and an angle of refraction of 29 degrees, the index of refraction for the unknown medium can be calculated. Understanding how to manipulate Snell's Law and apply inverse sine is crucial for solving related problems.
  • Understanding of Snell's Law and its formula
  • Basic knowledge of indices of refraction
  • Familiarity with trigonometric functions, particularly sine and inverse sine
  • Calculator proficiency for trigonometric calculations
  • Practice solving Snell's Law problems with different media
  • Learn how to derive the index of refraction using Snell's Law
  • Explore applications of Snell's Law in optics and physics
  • Study inverse trigonometric functions and their applications in isolating angles
Students preparing for physics tests, particularly those focusing on optics and wave behavior, as well as educators teaching Snell's Law and its applications.
bflatt
Snell's Law HELP! TEST TOMMOROW!
Hi, I have a problem with Snell's Law...i understand that it is:
but for the test, we need to know how to manipulate the problem to find the angle of refraction...i will have a calculator to plug thing in but i just don't understand how to! Apparently after you find one thing you need to use an inverse sin (sin-1) or something...PLEASE HELP!
An example problem for this is:
A Beam of light passes from glass (n=1.51) to an unknown medium X (nX=?).
If the angle of incidence is 40 and the angle of refraction is 29 then the index of refraction of the unknown medium is closest to:
a)1.17, b)1.38, c)1.63, d)1.83 or e)2.00
Followed by: The beam of light exists medium X and enters air. If it has an incident angle of 29 at the X-Air boundary, find the angle of refranction in the air?
for example my notes say: Nw(sin)theta W = Na(sin)theata A
w=water=1.333
a=air=1
1.333(sin)theta W=1 x sin(37)(angle of incidence)
sin thetaW=sin(37)/1.333
Theta W= (sin -1)/(inverse sin) [sin(37)/1.333]
WHY IS IT GO FROM SIN(theta W) TO INVERSE SIN!?
I Know there is a lot fo questions and info here...these are questoins from a quiz i did and i did very poorly...my test is tommorow and help would be greatly appretiated THANKS SOOO MUCH!
To explain the inverse trig function part:
Starting with this line of your example:
sin(theta_w)=(sin37/1.333)
The sin^-1 (or inverse sin, also called arcsin) is just a function that you use to "undo" the sin(theta_w) to get just theta_w. You apply it to both sides of your equation like you would anything else when trying to isolate a variable. So you would have
sin^-1{sin(theta_w)} = sin^-1{sin37/1.333}
the left side then becomes just theta_w, and by calculating the right side you get the angle of refraction.
ooooo thanks so much...the test was still REALLY hard but what can you do...thanks a ton i appreatiate it
31K
24K
