So confused Kinematics in one dimension
The discussion revolves around a kinematics problem involving a hot air balloon ascending at a constant speed and a pellet fired upwards from the ground. Participants are trying to determine the points at which both the balloon and the pellet reach the same altitude simultaneously.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster expresses confusion over their calculated answers and seeks assistance in identifying errors. Other participants inquire about the methods used to arrive at those answers. One participant mentions using the quadratic formula to solve the problem and shares their calculations.
Some participants are actively sharing their approaches and calculations, while others are questioning the correctness of the original poster's answers. There is an ongoing exploration of the methods used to find the points of intersection in altitude.
Participants are discussing the need to equate the heights of the pellet and the balloon to find the solution, indicating a focus on the relationship between their respective motions. There may be assumptions regarding the initial conditions and the equations of motion being applied.
PhysicFailure
A hot air balloon is ascending straight up at a constant speed of 8.80 m/s. When the balloon is 12.0 m above the ground, a gun fires a pellet straight up from ground level with an initial speed of 31.0 m/s. Along the paths of the balloon and the pellet, there are two places where each of them has the same altitude at the same time. How far above ground level are these places?
I got 0.628 and 3.90 for my answers and they're wrong! I don't know what I did but I can't find what I did wrong! help please!
how do you get 0.628 and 3.90 .show us
oh i got the answer! I used this equation and used the quadratic formula:
-4.9t^2+t(Velocity of pellet gun-velocity of balloon)-12=0
then plugged those two answers into the following as is:
0.628 into distance of balloon=12+speed(0.628)= 17.5 m
and distance of pellet=initial speed(3.9)-((9.8(3.9^2))/2)= 46.4 m
Inorder to know where those meet in the same height you have to make equall
like pellet = gun
and you have to solve as you did above
