Solar cell Efficiency & thermal ?
The optimal temperature for solar cells is complex, as it is influenced by both cell temperature and solar irradiance. Generally, higher temperatures lead to decreased efficiency in solar cells, making cooler conditions preferable. The ideal scenario involves maximizing light intensity while minimizing cell temperature, though achieving this balance can be challenging and may require significant energy investment. The materials used in solar cell construction also play a crucial role in determining performance. Overall, maintaining a lower temperature while optimizing light exposure is key to enhancing solar cell efficiency.
ze-ro
Is 55°C best status for solar cells?
Science news on Phys.org
Where did you get this from? Increasing temperature generally decreases performance of solar cells as far as i understand.
how much is the best ?
It's complicated because the cell temperature and irradiance (energy density of the sun's rays) are linked assuming no artificial heating or cooling of the cell. In general if you heat a cell when the irradiance is fixed the efficiency will decrease. It also depends on the materials used in cell construction though.
Your question is too general to really give an answer, could you be more specific or give any more background to your question?
This is all true. But to try to answer your question, the colder the better. So what would be good is to make the incident light as intense as possible, but while keeping the cell as cold as possible. Now depending on how you aim to do this, you just might be spending too much power compared to what you are generating. Clearly there are trade-offs.
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
