Power Inverter + Solar Panel: Run DVR 24/7?
  • Thread starter Thread starter xRascal
    Solar Solar panel
To run a DVR 24/7 using a 150W solar panel and a 20A charge controller, the current setup is insufficient, especially if the DVR draws 5A continuously. Solar panels typically produce 15-20% of their rated power due to weather variations, and the inverter's inefficiency further reduces available energy. A minimum of 300W of solar panels is recommended to meet the energy demands, along with additional batteries for storage. The average draw of the DVR should be measured, as it may be lower than the rated peak load. Overall, more solar panels and batteries are necessary to ensure reliable 24/7 operation.
xRascal
hi i wonder be able to help me i got a 150w solar panel , and a 20a charge controller and two marine http://www.ebay.co.uk/itm/252019284625?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT i want to run the dvr box which is using around 12v 5a i want it to be on 24/7 do i have enough battery power to last that long ? also it be running off a 12v jack to the dvr box it self from the charge controller ?
also i have got a 2000w (4000W peak) power inverter 2000 watt 12v UPS inverter battery charger for backup and using tools now and again
Welcome to PF!
If the dvr is really pulling 5 amps, then no, you don't have enough power for it. Solar panels average 15-20% usage factor and obviously that is highly weather and season dependent. But if 5 amps is what the dvr nameplate says, it may not actually be pulling that much continuously. You may want to measure it.
With 150 amps of solar panels and deep discharge batteries, you should be able to supply 60 amp-hours of energy per day at the latitude of Florida/Arizona. At the latitude of Maine/Seattle, you need 50% more panels. On stormy days with thick clouds, your panel will only make 25% as much as on a sunny day. So, Russ Waters is correct, you don't have enough panels or enough batteries for a continuous 5 amp draw.
Six batteries and 400 watts of panels will be closer to serving your need, or you can maybe use a smaller amp or turn the volume down, or run it only part of the day.
That 2000 watt inverter is huge. In a few minutes it will suck up all the energy your panel makes in a day. Figure 1 kwH per day for 200 watts of panels. Also figure that inverters are only 50% efficient.
ah okay so you think if i get another solar panel think it be better ? like another 150 or 100w solar ? plus more batterys ? the cctv i can make it go to 12v 2amps
The solar panel power rating needs to be 4-6 times that of the load if you want to run the load 24/7. You indicated a 60 W load (120V,5A), so you need at least ~300 W of new PV panel array, or 360 W on the nameplate to still be producing at least 300 W twenty years from now. Depending on your latitude, you'll need less PV in the summer and more in winter, and more still on cloudy days. If you want the most power averaged across the year, mount your panels south facing at an angle equal to your latitude. If you want to buy just enough panel to maximize winter production at the expense of a lower annual average power production, mount the panels more steeply.
As RussW indicated, the 60 W may be the *rating* of the DVR, i.e highest momentary load, but its average draw might be considerably less. You'll likely have to measure the DVR amps to know.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
