Does the Material Cu2OSeO3 Have a Solid-Liquid Critical Point?
The discussion focuses on the existence of solid-liquid critical points in materials, specifically addressing the material Cu2OSeO3. It highlights that most substances lack a solid-liquid critical point due to the simultaneous breaking of translational and rotational symmetries during phase transitions. The Landau theory is referenced as a framework for understanding these transitions, emphasizing the need for a system with an intermediate phase that breaks only one symmetry for a continuous transition. The Kosterlitz-Thouless-Halperin-Nelson-Young (KTHNY) theory is also mentioned as a model for continuous transitions in two-dimensional systems.
  • Understanding of phase diagrams and critical points
  • Familiarity with Landau theory and symmetry breaking
  • Knowledge of Kosterlitz-Thouless-Halperin-Nelson-Young (KTHNY) theory
  • Basic concepts of crystalline and amorphous solids
  • Research the Landau theory of phase transitions
  • Explore the Kosterlitz-Thouless-Halperin-Nelson-Young (KTHNY) model in detail
  • Investigate the properties of intermediate phases in materials
  • Study the phase diagram of Cu2OSeO3 and its implications for solid-liquid transitions
Researchers in condensed matter physics, materials scientists, and anyone interested in the thermodynamic properties of phase transitions and critical phenomena.
jfizzix
Insights Author
In many phase diagrams of a single substance, there is a triple point, where the solid, liquid and gas phases coexist in equilibrium, and there is a liquid-gas critical point beyond which, the transition between liquid and gas becomes continuous, and the substance is known as a super-critical fluid.
Is there a simple reason why in most substances there doesn't appear to be a solid-liquid critical point, where, say pressures are so large that solids can flow (e.g., the mantle of the Earth)? Is there a special distinction between crystalline and amorphous solids as far as this point goes? Are there substances with known phase diagrams that have solid-liquid critical points?
The explanation of the (generic) non-existence of such a critical points lies in Landau theory. The main idea is to study the ways in which symmetry can be broken in the system, write down an analytic functional for a coarse-grained order parameter which can describe that symmetry breaking (the functional must satisfy all the symmetries of the microscopic system), and then to study how many parameters need to be tuned to obtain a critical point (that is, a non-analyticity in the free energy which is not a simple discontinuity in either the free energy itself or its first derivative).
In this approach, the issue with finding a critical point in the solid-liquid transition is that too many symmetries are broken at once in going between the two phases, since a solid simultaneously breaks the translational and rotational symmetries of the liquid. If you write down the Landau functional needed, the number of parameters which you need to tune in order to get a continuous transition is more than you have to play with in real life (where you usually just have, say, just temperature and pressure).
Yes, the existence of intermediate solid-like phases is the work around! If you have a system which can have an intermediate phase between the liquid and solid which breaks only one of the two symmetries, then you can imagine going from a liquid to a solid with critical transitions. For example, in two dimensions there can be an intermediate hexatic phase, and the famous "Kosterlitz-Thouless-Halperin-Nelson-Young" (or KTHNY) proposal outlined how transitions between the three phases can be continuous. I believe nematic systems can also undergo a multi-step series of transitions between liquid and solid phases which can be continuous in principle.
Do you know of any substances that have this property?
I only know of the examples I gave.
Here is a very recent paper outlining the melting of a skyrmion lattice via an intermediate hexatic phase in the material Cu##_{2}##OSeO##_{3}##. It touches directly on many of the things king vitamin detailed.
https://arxiv.org/pdf/1807.08352.pdf
9K
9K
