Are there any materials where ions are the charge carriers instead of electrons?
This discussion centers on the use of ions as charge carriers in materials, contrasting them with traditional electron-based conduction in metals. Electrolytes, such as those found in batteries, conduct electricity via ions, typically exhibiting lower conductivity than metals. Notable examples include zirconium oxide membranes in lambda sensors, glass electrodes for pH measurement, and sodium beta-alumina used in high-energy batteries. The resistance of ionic conductors is generally higher than that of metallic conductors at room temperature.
  • Understanding of ionic conduction in electrolytes
  • Familiarity with P-type semiconductors and their charge carriers
  • Knowledge of electrical characteristics of materials
  • Basic principles of electromagnetism and magnetic fields
  • Research the properties of zirconium oxide in ionic conduction applications
  • Explore the functionality of glass electrodes in pH measurement
  • Investigate sodium beta-alumina and its role in battery technology
  • Learn about the electrical characteristics of P-type semiconductors
Researchers, materials scientists, electrical engineers, and anyone interested in the principles of ionic conduction and its applications in technology.
Salvador
I was wondering , are there any materials , metal or others, that have ions as the charge carriers that form current instead of electrons as in most metals.?
and are the ohmic resistance in room temperature for example similar to materials were current is formed by electrons or is the resistance higher?Also if I can add , I would like to know , if I have two wires connected together , one is an oridnary wire with electrons forming current and the other wire has ions carrying current , now if i move both wires the same way through a magnetic field , would i have a single loop of current as in the current in one wire would go one way while the current in the ion wire would go the other way or would the currents both go the same way as would happen if both wires were made of ordinary copper?
thanks.
Electrolytes conduct electricity using ions rather than electrons. The conductivity is typically lower than for metal.
thanks.
Like Dale said, electrolytes conduct electricity via ions rather than electrons. In P-type semiconductors, positively charged 'holes' in the crystal lattice are the majority charge carriers rather than electrons. As far as I know, there are no solid materials where actual ions are the charge carriers. Whether or not that's even theoretically possible is kind of an interesting question, maybe someone on here will know more. You can look up the electrical characteristics of semiconductors, and as you can imagine they vary considerably depending on the material. P-types are very commonly used though, and you can find them in BJTs, FETs, etc.
In fact, there are some examples: The lambda sensor in cars measures the oxygen concentration using a Zirconium oxide membrane which conducts oxygen ions at elevated temperatures. Another example are glass electrodes as used to measure the pH of solutions. There, hydrogen ions can move through the glass membrane. Another important material is sodium beta-alumina which is used in several high energy batteries. The sodium ion can move in the crystal lattice, here.
  • · Replies 0 ·
  • · Replies 36 ·
  • · Replies 17 ·
