Soln: Acceleration of System & Tension in Ropes
The discussion revolves around determining the acceleration of a system involving multiple masses and tensions in ropes, set within a triangular configuration with pulleys. The problem includes kinetic friction and specific angles, requiring a careful analysis of forces acting on each mass.
  • Mixed
  • Participants discuss the equations of motion for each mass and express uncertainty about the correctness of their calculated acceleration values. There are attempts to verify algebraic manipulations and substitutions within the equations.
Some participants have provided feedback on the equations presented, suggesting that while the equations appear correct, the calculated acceleration values seem implausible. There is an ongoing exploration of different approaches, including the potential use of vectors.
Participants note the presence of kinetic friction and the specific angles involved, which may influence the calculations. There is also mention of potential errors in algebraic manipulation and substitutions that could affect the results.
kj99
Find the Acceleration of the system and the tensions in the three ropes.
*If you can't see the picture there's a triangle (ABC), a train of four objects and three pulleys (one exactly at each corner). Side AC (hypotenuse) at the bottom, side AB to the left and side AC to the right.
Angle A=37
Angle B=53
Angle C=90
There is only kinetic friction between A and B of 0.125.
mass A= 10kg (hangs straight off the pulley at Angle A)
mass B= 5kg (on AB)
mass C= 10kg (on BC)
mass D= 20kg (hanging off the pulley at Angle C)
Up is positive
I got an acceleration of 28.96m/s/s but I'm fairly sure it's wrong lol. I used these equations using scalar values:
m1: Fnet= T1 - Fg
10a= T1 - (10)(10)
T1= 10a+ 100
m2: Fnet= T2 -T1 - Fres - Fg//
5a= T2 - T1 - (0.125)(50cos37) - 50sin37
T2= T1 + 5a + 35.08
m3: Fnet= T3 + Fg// - T2
10a= T3 + 100sin53 - T2
T3= T2 + 10a -79.86
m4: Fnet= Fg - T3
20a= 200 - T3
T3= 200-20a
After finding these four equations I just started at the last equation and kept substituting from there.
Your equations look correct. But as you noted, your final answer for the acceleration can't be correct. ( It's greater than free fall acceleration.) I guess you will need to check your algebra. It's easy to slip up on a sign or something.
Is this how you would approach and solve this question?
Yes. But what would happen if you added all the red equations below:
m1: Fnet= T1 - Fg
10a= T1 - (10)(10)
T1= 10a+ 100
T2= T1 + 5a + 35.08
T3= T2 + 10a -79.86
m4: Fnet= Fg - T3
20a= 200 - T3
T3= 200-20a
Yeah I tried it again and I got 7.66m/s/s. I probably messed up in my substitutions somewhere along the way.
Darn. That's not what I get. Of course I could be making an error in solving the equations. (But I did check my work.)
Lol idk, I'll try the question with vectors instead of vectors maybe.
I still like my suggestion in post #4.:smile:
  • · Replies 38 ·
11K
