Solution to the heat equation from a source
The discussion focuses on solving the heat equation for a system where heat is transmitted from a source at a higher temperature to a reservoir at a lower initial temperature, with one end exposed to a fixed ambient temperature. A differential equation is proposed to model the heat flow, considering the effects of convection as heat transfers to the air. The scenario also explores variations in room temperature, such as when a heater is introduced. The complexities of heat transfer due to convection are acknowledged, emphasizing the need for precise modeling. Overall, the conversation highlights the importance of understanding heat flow dynamics in practical applications.
Adel Makram
What is the best solution of the heat equation that described a transmission of heat from a source kept at certain temperature to a reservoir with an initial constant temperature (lower than the source) where its ends are not insulated from the surroundings and the surrounding is kept at a fixed temperature. For example, heating one end of a metallic rod while the other end is not insulated but exposed to the room of a constant temperature. What if the room temperature is allowed to rise like in case of a heater?
Science news on Phys.org
Write down a differential equation for the heat flow in your setup, solve it.
Heat transfer to air can be complicated due to convection.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
