Solution to the Schrodinger Equation
In summary, the equation \psi_E(x) = Aexp(ikx)+Bexp(-ikx) is the solution to all equations of the form \frac{d^2\psi(x)}{dx^2} = \frac{2m}{\hbar^2}(V_{0} - E) \psi(x) for a free particle under a constant potential. This solution is valid for E > V_{0} and for real values of the constant k. The general solution is a linear combination of all linearly independent solutions, which in this case are energy eigenfunctions for the free particle.
ehrenfest
2,020
I am somewhat confused about how general the solution [tex] \psi_E(x) = Aexp(ikx)+Bexp(-ikx) [/tex]
is?
Can someone complete one or both of these sentences:
is the solution to all equations of the form ...
or
is a solution to the Schrodinger equation when...
They are the solutions when the potential is constant, and if you mean k to be real, then when the energy is greater than the potential. Haven't we just been working on such problems? These are the free particle solutions.
Perhaps not required, but I will add to what Dick said:
The 1D Time Independent Schrodinger Equation,
[tex]-\frac{\hbar^2}{2m}\frac{d^2\psi(x)}{dx^2} + V(x)\psi(x) = E\psi(x)[/tex]
for a free particle (under a constant potential [itex]V_{x} = V_{0}[/itex]) becomes
[tex]\frac{d^2\psi(x)}{dx^2} = \frac{2m}{\hbar^2}(V_{0} - E) \psi(x)[/tex]
For [itex]E < V_{0}[/itex], solutions to this equation have the form stated in your first post. This happens, as Dick as pointed out, for real values of the constant k.
If you are asking how the general solution is a sum of the two solutions, then, well, that is a basic theorem for linear differential equations which says that if you can find two linearly independent solutions, then their linear combination is also a solution (as may be verified easily by substitution). The general solution is a linear combination of all linearly independent solutions (which in this case will be energy eigenfunctions for the free particle).
Did you mean to write [itex]E > V_{0}[/itex]?
Yes, I apologize for the typo. Please read it as [itex]E > V_{0}[/itex].
1. What is the Schrodinger equation and what does it represent?
The Schrodinger equation is a fundamental equation in quantum mechanics that describes the behavior of a quantum system over time. It represents the wave function of a system and how it evolves in time.
2. What is the significance of finding a solution to the Schrodinger equation?
Finding a solution to the Schrodinger equation allows us to predict the behavior and properties of quantum systems, such as atoms and molecules. It also allows us to understand the underlying principles of quantum mechanics and its applications.
3. How is the Schrodinger equation solved?
The Schrodinger equation is solved using mathematical techniques, such as separation of variables and eigenvalue equations. In some cases, analytical solutions can be found, but in more complex systems, numerical methods are used.
4. What are some applications of the Schrodinger equation?
The Schrodinger equation has many practical applications, including in the fields of chemistry, materials science, and quantum computing. It is also used in the development of new technologies, such as lasers and transistors.
5. Are there any limitations to the Schrodinger equation?
While the Schrodinger equation is a powerful tool for understanding and predicting the behavior of quantum systems, it has some limitations. For example, it does not take into account the effects of relativity and cannot fully describe the behavior of particles at high energies.
  • Quantum Physics
  • Differential Equations
