Solutions for x<0: Konig's Method
  • Thread starter Thread starter Konig
Konig
Hi,
I have solved a differential equation (1) for x, where i think is a real variable.
(1) \frac{dy}{dx} = \frac{1}{x^{\frac{3}{2}} (1+x)^2}
And get a solution
y(x) = \frac{2}{\sqrt{x}} - \frac{\sqrt{x}}{(1+x)} - 3 \arctan{\sqrt{x}}
Now, i want to find solutions for x<0, and i have said that the above is a solution for x>0.
So far i have simply done a coord transformation x→-x and then solved this equation
\frac{dy}{dx} = \frac{1}{x^{\frac{3}{2}} (1-x)^2}
and then substituted in "-x" under my square roots.
Is this a correct way of finding x<0?
Konig.
Konig said:
Hi,
And get a solution
y(x) = \frac{1}{\sqrt{x}} - \frac{\sqrt{x}}{(1+x)} - 3 \arctan{\sqrt{x}}
Konig.
What do you plan to do about the square root of negative numbers?
Konig.
So \sqrt{-x}, x&lt;0 will give a positive answer.
Although I am not sure what to do about the x^{\frac{3}{2}} part of the equation.
The answer should have natural logs and some x terms.
the solution of \frac{dy}{dx} = \frac{1}{x^{\frac{3}{2}} (1-x)^2}
gives a similar answer to what i need which gives me hope. But I am not sure what the do with the first terms, eg there signs etc.
thanks.
You can't arbitrarily change the sign of x under the radical.
This will show the problem:
\displaystyle\sqrt{x}=\sqrt{(-1)(-1)x}
\displaystyle =\left(\sqrt{-1}\,\right)\sqrt{-x}​
What will you do with \sqrt{-1}\,? -- even if you call it i .
