Solve an exponent equation without restricting the domain?
  • Level: Undergrad
  • Thread starter Thread starter Hertz
    Domain Exponent
6 replies · 2K views
Hertz
It's a pretty basic equation:
x = x^u, solve for u.
ln x = u ln x
ln x / ln x = u
u = 1
However, this solution only applies for x > 0. Is there any way we could solve this equation for all values of x?
Mathematics news on Phys.org
The equation has infinitely many solutions when x = 0, so you're going to have to partition the domain anyway. For negative values of x specifically, you might try toying with the inverse of xu...
Hey Hertz and welcome to the forums.
Are you are aware of complex numbers and Eulers identity?
I do know about complex numbers, but not Eulers identity. I am more than happy to do research though to solve this problem.
I'm not sure that xu is defined on the reals when x negative. If taking x and u to be complex then try substituting x = r.eiθ, r ≥ 0.
I'm not 100% sure if this situation is case specific, but using Euler's Identity I think I've proven it for u < 0 also.
Euler's Identity: e^ipi + 1 = 0
e^ipi = -1
ln(-1) = ipi
Therefore:
ln(-a) = ln(-1) + ln(a)
ln(-a) = ipi + ln(a)
x^u = x
u ln x = ln x
u = ln x/ln x
Even if x is negative, the ln x's still cancel out.
so, u = 1 for all x such that x != 0.
Thank you for the suggestion chiro.
One final quick question; using a Maclaurin or Taylor series would it be possible to evaluate ln x when x = 0? Sorry if this question sounds foolish, I haven't learned much about them yet.
The series would diverge, as the logarithm would.
