Solve "Calculator Problem" Homework - x,y Parametric Equations, Graph, c & d
  • Thread starter Thread starter Lindeza
    Calculator
The discussion revolves around solving a homework problem involving the parametric equations for the path of supplies dropped from an airplane. The key equations discussed are x=t*300 and y=t*(-16)t²+3500, with the first equation representing horizontal distance and the second representing vertical height. The user is struggling to graph these equations correctly on a TI-84 calculator, suspecting that their initial equations may have been incorrect. There is a focus on understanding the physical meaning of the equations and ensuring they are set up properly for graphing. The conversation highlights the importance of correctly interpreting the equations to visualize the supplies' trajectory effectively.
Lindeza
An airplane flying at an altitude of 3500 feet is dropping supplies to researchers on an island. The path of the plane is parallel to the ground at the time the supplies are released and the plane is traveling at a speed of 300 mph.
a) write the parametric equations that represent the path of the suppies
b)graph the path of the suppies on your graphing calculator and sketch the graph.
c)How long will it take for the supplies to reach the ground?
d) how far will the suppies travel horizontally before they land?
I think I can do c and d, but I can't figure out b. The graph won't work.
Its probably just that my equations are wrong. I have tried several window settings on my calculator ( Ti-84), the calculator is set in parametric mode&degrees, but it won't work.
Thanks for your help :)
I came up with these equations: (although I know that the first equation equals zero...)
x=t*l300l*cos(90)
y=t*l300l*sin(90)+1/2*(-32)t²+3500
Hi again Lindeza! :smile:
hmm … funny that … i wonder why that is … ? :wink:
i] what is the physical meaning, in ordinary language, of x=t*l300l*cos(90)
in this context?
ii] are you sure it's cos? :smile:
I think I know what it is now...:)
the y equation is correct, but the x equation is
x=t*300...
and I just graphed it without my calculator...still don't know why it didn't work...
but thanks for your help anyways!
:smile:
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
