Solve Exponential Function: 2 Questions | Help Needed
In summary, it is suggested to use the rule a^xa^y=a^{x+y} to simplify the expressions in both problems. For the first problem, recognizing that 4/3 is equal to (3/4)^-1 and 9/16 is equal to (3/4)^2 allows for the bases to be the same and the equation to be solved easily. For the second problem, setting t=3^x and solving the resulting quadratic equation will lead to the solutions x=-1 and x=2/3.
love_joyously
i'm having problems with two questions. Please help me! Thanks! I've tried everything but i can't solve them... :confused: :frown:
1) Solve: (3/4)^3x-2 * (4/3)^1-x = 9/16
2) Solve for x : 3(3^x) + 9(3^-x)=28
Could you please show us what you've tried?
Well for no. 1 this is what I've tried but i keep getting the wrong answer:
*2nd step* 3^3x-2/ (2^2)^3x-2 * (2^2)^1-x/3^1-x = 9/16
3^3x-2/2^6x-4 * 2^2-2x^3^1-x = 9/16
2^-8x+6/3^-4x+3 = 3^2/2^4
Therefore, -8x+6/-4x+3 = 1/2
-16x +12 = -4x +3
-12x = -9
x = 3/4
*the answer was 5/4*
and for no.2 i have no idea what my next step is...
There's a much easier way.
First, recognize that [itex]\frac{4}{3}=(\frac{3}{4})^{-1}[/itex] and that [itex]\frac{9}{16}=(\frac{3}{4})^2[/itex].
Once you do that, all the bases will be the same. Then you can apply the rule [itex]a^xa^y=a^{x+y}[/itex] to simplify the left side, and then solve the equation.
You'll want to do something similar to reduce the left side of #2 to a single term.
I'm trying to follow your work, but it's very difficult to read.
Here is your second step in Latex form. Maybe you could rewrite the next steps.
[tex]\frac{3^{3x-2}}{(2^2)^{3x-2}}*\frac{(2^2)^{1-x}}{3^{1-x}}[/tex]
yeah, sure, ill try. Then ill let you know
i tried it but i keep eliminating my variable
How? When you add the exponents, the variable does not cancel out.
ok.. well this is what i did:
3^3x-2/2^6x-4 * 3^x-1/2^2x-2 = 3^2/2^4
3^4x-3/2^8x-6=3^2/2^4
Therefore, 4x-3/8x-3 = 1/2
*cross-multiply* 8x-6 = 8x-6
0=0
This step is wrong.
You'll have better luck if you don't use different exponents for the numerator and denominator.
[tex]\left(\frac{3}{4}\right)^{3x-2}\left(\frac{3}{4}\right)^{x-1}=\left(\frac{3}{4}\right)^2[/tex]
Now you can simply add the exponents on the left side, and solve for x.
ook.. i get : (3/4)^4x-3 = (3/4)^2
wat now?
See how the bases are equal? That means that the exponents must be equal in order for the equation to hold. Set them equal, then solve for x.
wat now?
I know know this problem,
4x-3=2
then x=5/4
oh..ok! now i get it.. thanks!
so for no. 2, what do u suggest me do?
let t=3^x then Solve for t : 3t^2 -28t + 9=0
Yeah..
Yeah..
That's what I would do, too. Solve that quadratic equation, then solve for x.
I was trying to follow what you did to arrive at the quadratic expression.
It seems you multiplied the original equation by [itex]3^x[/itex]
[itex] 3^x [ {3(3^x)+9(3^{-x})=28}] [/itex]
[itex] 3(3^x)^2 +9 = 28(3^x) [/itex]
[itex] 3(3^x)^2 -28(3^x) +9 = 0 [/itex]
And If [itex] t = 3^x [/itex] then [itex] 3t^2-28t+9=0 [/itex]
With a bit of http://www.deephousepage.com/smilies/OLA.gif I get, x = -1, 2
Related to Solve Exponential Function: 2 Questions | Help Needed
What is an exponential function?
An exponential function is a mathematical function of the form f(x) = ab^x, where a and b are constants and x is a variable. The variable is typically an exponent and the base is typically a positive number greater than 1. Exponential functions grow or decay at a constant rate.
How do I solve an exponential function?
To solve an exponential function, you can use logarithms, graphing, or algebraic techniques. Logarithms can help you solve for an unknown exponent, graphing can help you visualize the function, and algebraic techniques can help you solve for specific values of the function.
What are some real-life applications of exponential functions?
Exponential functions can be used to model many real-life situations, such as population growth, compound interest, radioactive decay, and bacterial growth. They can also be used in fields like economics, biology, and physics.
What is the difference between exponential growth and exponential decay?
Exponential growth occurs when the base of an exponential function is greater than 1, causing the function to increase rapidly. Exponential decay occurs when the base is between 0 and 1, causing the function to decrease rapidly. In both cases, the function is continuously increasing or decreasing at a constant rate.
How can I check if my solution to an exponential function is correct?
To check if your solution to an exponential function is correct, you can substitute the value of the variable into the original function and see if it equals the given output. You can also graph the function and see if your solution lies on the graph.
  • Precalculus Mathematics Homework Help
  • Differential Equations
