Solve for a constant in an equation
The discussion revolves around solving for a constant in an equation involving the arctanh function, specifically arctanh(6.55). Participants explore the implications of this calculation and the resulting errors encountered on calculators.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant expresses difficulty in calculating arctanh(6.55) and seeks alternatives.
  • Another participant suggests using hyperbolic trigonometric identities, specifically the definitions of tanh and arctanh, to clarify the situation.
  • A participant points out that the values of the tanh function are restricted to the range between -1 and 1, implying that arctanh(6.55) is not valid within the real number system.
  • A later reply reiterates that there is no real number x such that tanh(x) equals 6.55, explaining the error encountered on the calculator.
Participants generally agree that arctanh(6.55) is not valid for real numbers due to the range of the tanh function, but the discussion includes multiple perspectives on how to approach the problem.
Limitations include the assumption that only real numbers are considered, and the need for clarity on the specific equation being solved.
Dean Whaley
Im trying to solve for a constant in an equation and it involves taking the arctanh(6.55) and my calculator is giving me an error, is there a way around this?
Mathematics news on Phys.org
Perhaps you could make use of $$\tanh(x) = \frac{\sinh(x)}{\cosh(x)} = \frac{e^x - e^{-x} }{ e^x + e^{-x} },$$ or $$\mathrm{arctanh}(x) = \frac{1}{2}\,\ln\left|\frac{1+x}{1-x} \right|.$$ These are all available by Googling "Hyperbolic trig identities".
Also, you should probably mention what the equation is.
This helps, thanks a lot
The values of tanh are between -1 and 1.
What you are trying to do is like asking for arcsin(2).
Of course you get an error.:)
If you let x = arctanh(6.55), an equivalent equation is tanh(x) = 6.55.
Assuming that we're dealing only with real numbers, the range of the tanh function is ##-1 < \tanh(x) < 1##. This means that there is no real number x for which tanh(x) = 6.55, or equivalently, for which x = arctanh(6.55). That's what your calculator is telling you.
Your calculator probably has some documentation about the values that can be used as arguments to each of the calculator's functions.
Edit: nasu beat me by 2 minutes!
  • · Replies 52 ·
10K
  • · Replies 32 ·
