MHB Solve IVP: What is the solution to the given initial value problem?
  • Thread starter Thread starter karush
    Ivp
karush
MHB
$\tiny{b.2.1.16}$
\begin{align*}\displaystyle
y^\prime +\frac{2}{x}y &=\frac{\cos x}{x^2} &&(1)\\
u(x)&=\exp\int\frac{2}{x} \, dx = e^{2\ln{x}}=2x&&(2)\\
(2x y)'&=\int\frac{\cos x}{x^2} \, dx &&(3)\\
y(x)&=\frac{1}{2x}\left[-\dfrac{\cos(x)}{x}-\int\dfrac{\sin(x)}{x}\, dx\right] &&(4)\\
y(\pi)&=0 &&(5)\\
&=\frac{1}{2(\pi)}
\left[-\dfrac{\cos(\pi)}{\pi}
-\int\dfrac{\sin(\pi)}{\pi}\, dx
\right]=0 &&(6)\\
&=\color{red}{\frac{\sin x}{x^2}}&&(7)\\
&=\frac{0}{\pi^2}=0 &&(8)
\end{align*}
ok (4)-(8) were ? red is bk answer
Your integrating factor is incorrect. Try finding that again. :)
$\tiny{2.1.{8}}$
y^{\prime} +\frac{2}{x}y &=\frac{\cos x}{x^2} &&(1)\\
u(x)&=\exp\int\frac{2}{x} \, dx = e^{2\ln{x}}=x^2&&(2)\\
(x^2 y)'&=\int\frac{\cos x}{x^2} \, dx &&(3)\\
y(x)&=\frac{1}{x^2}\left[-\dfrac{\cos(x)}{x}-\int\dfrac{\sin(x)}{x}\, dx\right] &&(4)\\
y(\pi)&=0 &&(5)\\
&=\frac{1}{\pi^2}
\right]=0 &&(6)\\
\end{align*}ok $u(x)=x^2$ red is bk answer
You now have the correct integrating factor, but you didn't multiply the RHS by this factor. :)
You should eventually get:
$$\frac{d}{dx}\left(x^2y\right)=\cos(x)$$
Now, continue from there.
$\displaystyle x^2y=\int \cos x \, dx$
$\displaystyle x^2y=\sin x$
$\displaystyle y=\frac{\sin x}{x^2}$
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
