Solve Limits & Derivatives Homework: y=-x+5
3 replies · 3K views
Ydoc
Find an equation of the tangent line to the curve at the given point.
y=(x-1)/(x-2), (3,2)
I've had several attempts at this, all of them are wrong. My solution book says the answer should be y=-x+5
One attempt I made is:
lim as h->0 [(3+h-1)/(3+h-2) - (x-1)/(x-2)]/h
lim as h->0 [(h+2)/(h+1) - (x-1)/(x-2)]/h
and I lost track of where I wrote the next step to this attempt. I've already attempted this 4 times.
you just need to use the general definition of a line:
(y-p)=m(x-r)
where (p,r) is the given point. and m is the slope.
To find the slope do you need to find the derivative and then evaluate for x=3.
But you don't need to use the definition of a derivative. just take the derivative of (x-1)/(x-2) using the quotient rule and then plug-in x=3 and you got your slope and plug in the point and slope into the formula and you'll get y=-x+5
(y-p)=m(x-r)
Thanks for the help.
The only problem I'm having currently is finding the derivative of (x-1)/(x-2). At this point in time my class hasn't learned the quotient rule yet, I checked the index and we don't learn it until the next chapter.
The only formula's that we were given in this section of this chapter is:
The tangent line to the curve y=f(x) at the point P(a,f(a)) is the line through P with slope:
m=lim as h->0 [f(a+h)-f(a)]/h
and
m=lim as x->a [f(x)-f(a)]/(x-a)
There's also a formula for instantaneous rate of change, but I don't think I need to use that for this problem.
I was able to do other problems like this, but they were stuff like y=x^2 .
o i see, well then you do have to use one of those definitions of the slope
[tex]lim_{h->0} \frac{\frac{h+2}{h+1}-\frac{x-1}{x-2}}{h}[/tex]
from here find a common denominator, to combine the fraction into 1 and you should get h to cancel.
