Solve LOG Problem: Evaluate Log 3 (Base 27) Without Calculator
  • Thread starter Thread starter TheNovice
    Log
To evaluate log base 27 of 3 without a calculator, it is essential to understand that log_{27} 3 means finding x such that 27^x = 3. Recognizing that 27 can be expressed as 3^3 simplifies the problem. By rewriting the equation, we find that 3^(3x) = 3, leading to the conclusion that 3x must equal 1. Thus, x equals 1/3, confirming that log_{27} 3 equals 1/3. This method provides a clear step-by-step approach to solving the logarithmic problem.
TheNovice
1. Evaluate WITHOUT using a calculator.
2. log base 27, 3, that is, log 3 with a base of 27 instead of 10
3. I'm stuck on how you end up with the solution, which is 1/3.
Can someone provide a step by step walk through on how to solve this problem without a calculator?
Well, any number, x, to the power of a fraction is defined such that x^\frac{a}{b} is equal to \sqrt<b>{x^a}</b>. Therefore log_{27} 3 is defined such that 27^x is equal to 3 and the only solution is 27^\frac{1}{3} and this is the same as the \sqrt[3]{27} which is equal to 3.
Thanks! that helped a lot!:cool:
  • · Replies 39 ·
  • · Replies 20 ·
  • · Replies 16 ·
