Solve ODE: y'(x)=-y(x)/√a^2-y(x)^2
  • Thread starter Thread starter justaboy
    Ode
The discussion revolves around solving the ordinary differential equation (ODE) given by y'(x) = -y(x)/√(a² - y(x)²). Participants are exploring various methods and substitutions to approach the problem, including a suggested substitution involving z² = a² - y².
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the classification of the ODE and suggest methods such as separation of variables and trigonometric substitution. There are attempts to integrate and express y as a function of x, with some questioning the feasibility of obtaining an explicit solution.
The discussion is active, with participants providing hints and nudges towards potential methods. There is recognition of the complexity of the problem, and while some participants express doubt about finding an explicit solution, others suggest alternative forms such as expressing x in terms of y.
Participants note the historical context of the problem, mentioning its connection to classical geometry and famous mathematicians. There is also a mention of the requirement to find y explicitly, which adds to the complexity of the discussion.
justaboy
Solve the ODE:
[tex]y'(x) = - \frac{y(x)}{\sqrt{a^2-y(x)^2}}[/tex]
To be honest I'm having trouble even classifying this ODE. My teacher hinted that the substitution [tex]z^2=a^2-y^2[/tex] could be helpful, but once I make the substitution, I can't seem to take the next step. I know I haven't shown much work, but if you could nudge me in the right direction I would be extremely grateful. Thanks.
Isn't this just http://en.wikipedia.org/wiki/Method_of_separation_of_variables" ?
If you separate it, you get
[tex]\frac{\sqrt{a^2-y^2}}{y}dy=-dx[/tex]
but I still have the same problem... how do I integrate the left side?
I would start with a trig substitution, say y = a sin(u).
Okay... after many trig subs, I found
[tex]a\log(a^3 y)+\sqrt{a^2-y^2}-a\log(2a\sqrt{a^2-y^2}+a) = -x[/tex]
How do I go about finding a y(x)?
That looks fine, but you forgot to add the constant of integration.
I don't believe that you can solve this equation for y as an explicit function of x. That's OK - just leave it in the form you have.
The question asks to solve for a curve y=y(x) explicitly.
I don't see any way of solving for y, so I don't have any advice for getting y = f(x), but you could write x = g(y). That would be pretty simple.
Does anyone see a way of solving for y=f(x)?
My teacher is quite positive that it can be done. Apparently this is an old geometry problem that Fermat, Descartes, Bernoulli and Leibniz worked on in the late 17th century... the curve y(x) should be such that the length of the segment of the tangent
to the curve between the curve and the x-axis is equal to a constant "a" at all points on the curve.
Why don't you just make the substitution like your teacher suggested?
Hint: Differentiate both sides of [itex]z^2=a^2-y^2[/itex] with respect to [itex]x[/itex].
On the right hand side you need to differentiate z with respect to x, not y. Forget about dz/dy. You want an expression that involves dz/dx. On the left hand side, you already know what dy/dx is. Use that knowledge.
Thanks very much. I end up with this:
[tex]\frac{dz}{dx}=\frac{a^2-z^2}{z^2}[/tex]
Which has turned out to be difficult to solve.
Tough, but doable. You should get x as a function of z, and from that, x as a function of y. Inverting this to get y as a function of x: Hmmmm.
Maybe he didn't mean for the z in the substitution to be squared.
