Solve Polarized Sphere Field: Find Charges & Calculate Field
  • Thread starter Thread starter aaaa202
    Field Sphere
aaaa202
A sphere with radius R carries a uniform polarization in the radial direction P = k/r2
Find the bound charges and calculate the field they produce outside the sphere.
ρ = -∇\bulletP
σ = P\bullet\hat{r}
We find σ = k/r2
ρ = 0
So the field they produce is E = kR2/(ε0r2)
But this can't be true! How can a polarization create a field outside the sphere? Something is definitely wrong. Because we also have:
D = ε0E
And using a Gaussian surface you find:
E=0
And I am confident in the last result. There is something disappearing in the above - where have all the charges of opposite sign gone? I believe it has to do with the mathematics behind ∇\bulletk/r2 = 0. For that the pesky delta function is involved in that I believe. If ρ=0 we also find no field inside the sphere. Can that really be true?
Let me check a couple of things: The polarisation is k/r2 in the radial direction, so how is it uniform polarisation? Also, I agree with your answer E = kR2/(ε0r2) due to the bound charges. Why do you think it is wrong?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
