What is the solution to y - 8y^(1/2) + 11 = 0 using quadratic formula?
  • Thread starter Thread starter DeanBH
    Quadratic
The discussion centers on solving the equation y - 8y^(1/2) + 11 = 0 using the quadratic formula, which initially confuses participants. The first part of the question, x^2 - 8x + 11 = 0, is solved using the quadratic formula, yielding x = 4 ± √5. Participants are encouraged to use substitution by letting y = x², which simplifies the second equation to the first. This substitution allows for a straightforward solution, as the previously solved x-values can be squared to find y. Ultimately, the key takeaway is that recognizing the relationship between y and x through substitution facilitates solving the equation effectively.
DeanBH
first part of the question is simple :
x^2 - 8x + 11 = 0
solve. using quadratic formula it is 4 +/- root5
second part confuses me, you are given to equation:
and are told to :
solve this giving answer in form p +/- Q * root5
i have no idea how to do this. the quadratic formula doesn't work on this one and i don't understand how part 1 of this question helps me with this part, can someone explain it to me please.!? thanks
Hint: Can you express y in terms of x, such that your second equation becomes your first?
i don't know how to do that, I've tryed making the equations equal to each other but it doesn't work out right
Compare the equations term by term.
11=11
next is...
oh yeah, i can do that because they're both 0, and are of the same form. lewl
Hint: substitution. :smile:
i've honastly tried for ages, i still don't know how to do it.
can someone just run me through it. it's not even a question for homework or anything I am just revising and i don't understand this.
Bigger hint: substitute y = x². :smile:
why can i just substitute that.
eh? :confused: You can substitute anything you like. :smile:
Some substitutions make the problem easier :!) , some substitutions make it harder. :mad:
But all substitutions are valid.
Try it … put y = x² into y - 8√y + 11 = 0, and see what happens! :smile:
think about it a second:
you've already found that x^{2} - 8x + 11
Now you need to find y - 8y^{1/2} + 11
If you substituted x^{2} = y,
you would have x^{2} - 8x + 11
which you already have the answer to. If x = 4+/-\sqrt{5},
what is x^{2} (i.e. y) going to equal?
  • · Replies 18 ·
  • · Replies 30 ·
