Solve Using Method of Node Voltages
This discussion revolves around solving a circuit problem using the method of node voltages, focusing on the values of V1 and V2 in a circuit with a voltage source and resistors. Participants are exploring the implications of their calculations and the relationships between different circuit components.
  • Homework-related
  • One participant states expected values for V1 and V2 as -3.214 V and -12.214 V, respectively, but struggles to match these with their calculations.
  • Another participant identifies a potential error involving a 1 ohm resistor and suggests that the current through it does not affect V1 and V2.
  • There are suggestions to use source transformation as a method to approach the problem.
  • One participant mentions that the voltage source in parallel with the resistor results in a constant current of 9 amps through the resistor, independent of V1 and V2.
  • Participants discuss the significance of accounting for different current paths in the supernode analysis and how they may cancel each other out.
  • A question arises about the voltage across a 5 ohm resistor and whether it would be -3.214 V or +3.214 V, leading to a discussion on the perspective of voltage measurements.
Participants express differing views on the necessity of accounting for certain terms in their calculations, indicating a lack of consensus on the approach to the problem. The discussion remains unresolved regarding the voltage measurement across the 5 ohm resistor.
Participants reference specific circuit elements and their relationships, but the discussion does not clarify all assumptions or dependencies, particularly regarding the treatment of the 1 ohm resistor and the implications of the voltage source.
mkematt96
[/B]
This problem was from a practice exam. I know what V1 and V2 should be but can't get my answer to match. V1 should be -3.214 V and V2 should be -12.214 V
See attached picture for my work. [/B]
What is this thing?
I see your problem. It involves the 1 ohm resistor...
Hint: There is a voltage source in parallel with the resistor.
There are two ways you can look at your error. Either you should not have added the (V1-v2)/1 term, because the current though the 1 ohm resistor in no way effects V1 and V2. The other way you can look at it, is you need to write the equations for every current path in and out of the super node, in which case you missed (v2-v1)/1/
So I re did the problem taking the (v2-v1)/1 ohm out of the problem and got the right answer. My question is, why don't we need to account for this?
There is a voltage source in parallel with the resistor. there will always be 9 amps going through the resistor, regardless of the other circuit conditions. It has no dependence on the value of V1 or V2
There are two current paths going to the resistor from your supernode. one going from V1 through the resistor counterclockwise, and one going from v2 through the resistor counterclockwise. You missed the counterclockwise one. If you were to write both equations, they would cancel each other out. Once you learn this will happen, you can just leave it out from the beginning.
Okay that makes sense thanks. One more quick question... Is the voltage across that 5 ohm resistor also -3.214 V or would it be positive 3.214 V ?
Voltage is a differential measurement, like height. If V1 is -3 V, then common usage says the voltage drop across the resistor is -3V. But one could describe the drop in the other direction (drop from the bottom end to the top) in which case the voltage would be positive.
An analogy to height... You're at the top of a mountain. Someone asks how high, you say 3000 feet down (-3000), because you are measuring from the top to the bottom. But then you ask someone else how big it is. they reply 3000 up. It is all about perspective.
  • · Replies 35 ·
