Solve Wave Equation with D'Alembert's Solution
  • Context: Graduate
  • Thread starter Thread starter actionintegral
9 replies · 4K views
actionintegral
Friends,
I have seen the wave equation solved by changing the coordinates to
u=x+ct and v=x-ct.
This is preposterous! Solve the wave equation by moving at the speed of light! Outlandish!
Use the relativistic D'Alembert's solution then..
Solution to what?
actionintegral said:
Friends,
u=x+ct and v=x-ct.
Um, the 'c' is just the speed appearing in the wave equation:
[tex]\frac{\partial^2 f}{\partial x^2}=\frac{1}{c^2}\frac{\partial^2 f}{\partial t^2}[/tex]
Could be the speed of sound or whatever. It depends on what the speed 'c' in your wave equation is.
Yes. Suppose c is the speed of sound. What is the effect of setting
u=x-ct? You are changing to a frame that is traveling at the speed of sound. Suppose c is the speed of light. What is the effect of setting u=x-ct? You are changing to a frame that is traveling at the speed of ... of ...
But so what? It's just a change of variable that will help you solve the equation. It has nothing to do with violating relativity if that's what you're thinking of.
Fair enough. Let me counter. Suppose I solve a physics problem by changing to a frame where
x= .99ct Can I do so with a clear conscience?
You're not 'changing to a frame'. You introduce new variables u and v to help solve the differential equation. It's mathematics, not physics. Mathematically you can make c 20 times the speed of light and you'll still get a solution to the differential equation in the form F(x+ct)+G(x-ct). In a relativistic physical theory you wouldn't find something that obeys that wave equation with c greater than lightspeed so that's not an issue.
I understand perfectly now. Saying "my friend is at x=5" and then saying "let u=x-5. My friend is at u=0" is distinct from saying "I am where my friend is".
That said, maybe someone can help me understand the d'alembert solution to the schroedinger equation. I did this with u=x+ct, v=x-ct.
Then I got nervous and changed the "c" to a "v".
Now I don't know what the h******ell to think.:confused:
...light, because you're solving the wave equation for light. The solution is a light wave moving with the speed of light "c".
