Solve Word Problem: Find a and b in T(t)=250-ae^(-bt)
  • Thread starter Thread starter betsinda
    Word problem
betsinda
A yam is pust in an oven maintained at a constant temp of 250degrees C. Suppose that after 30 min the temp of the yam is 150degrees C and is increasing at a rate of 3degrees C/min. If the temp of the yam t minutes after it is put in the oven is modeled by
T(t)=250-ae^(-bt), find a and b.
I have no idea how to even start. Please help
Just by looking at the question as stated, what are the values of:
T(30)
T'(30) ?
How can you use these to find a and b?
Hi betsinda! :smile:
Hint: what is Newton's law of cooling?
I think I have found b
180 = 250 - ae^-40b
150 = 250 - ae^-30b
-70 = -ae^-40b
70/e^-40b = a
-100 = -70/e^-40b * e^-30b
100/70 = e^40b * e ^-30b
10/7 = e^10b
ln 10/7 = 10 b
b = ln(10/7)/10
but how do I find a?
betsinda said:
70/e^-40b = a
10/7 = e^10b
a = 70e40b = 70(e10b)4 :wink:
Thank you !
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
11K
