B Solve x=Asin(ct) and y=Bsin(dt) for the period of the system of two equations
  • B
  • Thread starter Thread starter SSGD
    Period System
SSGD
I have been trying figure out how to solve the the period of the system of the two equations in the system. I have been searching for examples but this specific topic isn't documented on the internet very well or I'm not very good and searching. Any help would be appriciated.
Mathematics news on Phys.org
Try posting a specific question in the homework section.
It's not homework. And the above equations are the specific problem.
It is homework-like. It is unclear what you mean. Two separate systems with their own period? That is a standard textbook question. Do you look for a common period? Then the smallest common multiple (if existing) will be interesting.
Each equation has its own period. That is not an issue, there is also a sequence of times where both equations simultaneously repeat.
x(t+Tx)=x(t)
y(t+Ty)=y(t)
x(t+Ts)=x(t)
y(t+Ts)=y(t)
I am looks for Ts a time that satisfies both equations simultaneously.
Sorry for the unclear question.
Then you should use different symbols for the periods.
See above: the smallest common multiple (if it exists) will do the job. If it doesn't exist, there is no such period.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
