B Solve x=Asin(ct) and y=Bsin(dt) for the period of the system of two equations
  • B
  • Thread starter Thread starter SSGD
    Period System
To solve the period of the equations x=Asin(ct) and y=Bsin(dt), one must determine if there is a common period Ts that satisfies both equations simultaneously. Each equation has its own distinct period, and finding a common period involves calculating the smallest common multiple of these individual periods. If a common period exists, it will be the time at which both equations repeat their values together. If no common period can be found, then such a simultaneous period does not exist. Understanding the relationship between the periods of the two equations is crucial for solving the problem effectively.
SSGD
I have been trying figure out how to solve the the period of the system of the two equations in the system. I have been searching for examples but this specific topic isn't documented on the internet very well or I'm not very good and searching. Any help would be appriciated.
Mathematics news on Phys.org
Try posting a specific question in the homework section.
It's not homework. And the above equations are the specific problem.
It is homework-like. It is unclear what you mean. Two separate systems with their own period? That is a standard textbook question. Do you look for a common period? Then the smallest common multiple (if existing) will be interesting.
Each equation has its own period. That is not an issue, there is also a sequence of times where both equations simultaneously repeat.
x(t+Tx)=x(t)
y(t+Ty)=y(t)
x(t+Ts)=x(t)
y(t+Ts)=y(t)
I am looks for Ts a time that satisfies both equations simultaneously.
Sorry for the unclear question.
Then you should use different symbols for the periods.
See above: the smallest common multiple (if it exists) will do the job. If it doesn't exist, there is no such period.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
