How to Solve the Equation (x)^x^3=3?
  • Thread starter Thread starter racer
The equation (x)^x^3=3 can be interpreted in two ways: as x^(x^3)=3 or (x^x)^3=3, leading to different solutions. The first interpretation yields an algebraic solution of x=∛3, while the second requires numerical methods for an approximate solution of x≈1.31979. Discussions highlight the ambiguity of exponentiation without parentheses, emphasizing the importance of proper notation. Some participants mention using calculus and numerical methods like Newton's method to find solutions, but the original problem's interpretation significantly affects the outcome. Ultimately, clarity in expression is crucial for solving such equations accurately.
racer
Hello there
I've seen this question and tried to solve it but until now for no avail., I couldn't solve it but I know that the value of X is cubic root of 3
http://www.mathyards.com/attach/upload2/wh_45798340.bmp
Thanks.
Mathematics news on Phys.org
i don't think you can solve that analytically, instad you need to use numerical method?
Someone solved it by Calculus.
Do you have a reference for that? It certainly can be solved by "inspection"- noting that
\sqrt{3}^{\sqrt{3}^3}= \sqrt{3}^3= 3[/itex].<br /> <br /> But I have no idea what you <b>mean</b> by &quot;solved it by Calculus&quot;!
But I have no idea what you mean by "solved it by Calculus"!
I didn't understand how he solved it but I've seen Transcendental Functions, he derived something, I recall that there was Inverses and then he got e^1/3, if you still have no idea, tell me and I'll bring the solution from him.
<br /> Surely you mean<br /> \sqrt[3] 3^{\sqrt[3] 3^3} = \sqrt[3] 3^3 = 3
Yes, sorry. Very careless of me.
D H said:
Surely you mean
Seems easy to generalize:
x^{x^n}=n
\sqrt[n] n^{\sqrt[n] n \ ^n} = \sqrt[n] n \ ^n = n
x^{x^n}=n
An even more interesting generalization is
\underbrace{\sqrt[n]^n^{\sqrt[n]^n^{\dotsm^{\sqrt[n]^n}}}}_{n+1} = n
Why is it n+1 levels?
Not sure if this is interesting but changin the original problem somewhat:
x^{x^n}=m
And assuming a solution of the form:
x= \sqrt[n]{nq}
We find that q is determined as follows:
(nq)^q=m
it doesn't seem to matter at all how many levels you take it. for example
\sqrt [5]^5^{(\sqrt [5]^5)}^{5}=5
That is just a specific instance of John's generalization:
With n as the final power it does not matter how many levels you take it. Start with the tautology:
\sqrt[n] n \ ^n = n
Substituting \sqrt[n] n ^n for any of the ns on the left hand side of the tautology will yield a valid expression. Substituting for the power yields
\sqrt[n] n^{\sqrt[n] n \ ^n}= n
This substitution can be carried on indefinitely:
\sqrt[n] n ^{\sqrt[n] n ^{\cdots^{\sqrt[n] n \ ^n}}}= n
My "more interesting" generalization (post #9) replaces the final power (n) with with \sqrt[n] n. Changing the final power from n to \sqrt[n] n like I did in post #9 yields expressions like
\sqrt 2^{\sqrt 2^{\sqrt 2}} = 2
and
\sqrt[3] 3^{\sqrt[3] 3^{\sqrt[3]3^{\sqrt[3]3}}} = 3
and
How do you show that?
Don't you think this should read like this:
\sqrt[3] 3^{\sqrt[3] 3^{\sqrt[3]3^{\sqrt[3]3}}} = \sqrt [3]^3
Apologies first: I should have used parentheses. Without parentheses, exponentiation evaluates right-to-left. Post #9 is correctly written as
\underbrace{\sqrt[n] n^{\left(\sqrt[n] n^{\left(\dotsm^{\sqrt[n] n}}\right)}\right)}_{n+1} = n
Taking the log (base n) of the left hand side,
\log_n\Biggl(\underbrace{\sqrt[n] n^{\left(\sqrt[n] n^{\left(\dotsm^{\sqrt[n] n}}\right)}\right)}_{n+1}\Biggr) =<br /> \sqrt[n] n \,<br /> \log_n\Biggl(\underbrace{\sqrt[n] n^{\left(\sqrt[n] n^{\left(\dotsm^{\sqrt[n] n}}\right)}\right)}_n\Biggr) =<br /> {\sqrt[n] n}^{\;2} \,<br /> \log_n\Biggl(\underbrace{\sqrt[n] n^{\left(\sqrt[n] n^{\left(\dotsm^{\sqrt[n] n}}\right)}\right)}_{n-1}\Biggr) =<br /> \cdots =<br /> {\sqrt[n] n}^{\;n} \log_n \left(\sqrt[n] n\right) = n\cdot \frac 1 n = 1<br />
WOW, nice trick!
Given where you placed the parenthesis, I still don’t follow.
Step by step, then. The problem is to evaluate
To do so I will take the base-n log of this expression. Using \log a^b = b\log a
\log_n\Biggl(\underbrace{\sqrt[n] n^{\left(\sqrt[n] n^{\left(\dotsm^{\sqrt[n] n}}\right)}\right)}_{n+1}\Biggr) =<br /> \sqrt[n] n \,<br /> \log_n\Biggl(\underbrace{\sqrt[n] n^{\left(\sqrt[n] n^{\left(\dotsm^{\sqrt[n] n}}\right)}\right)}_n\Biggr)<br />
We still have something of the form \log a^v. Applying the identity again yields
After doing this m&lt;n times, the expression becomes
<br /> {\sqrt[n] n}^{\;m} \,<br /> \log_n\Biggl(\underbrace{\sqrt[n] n^{\left(\sqrt[n] n^{\left(\dotsm^{\sqrt[n] n}}\right)}\right)}_{n+1-m}\Biggr)<br />
After applying this identity n times, the log (base n) of the original expression becomes
<br /> {\sqrt[n] n}^{\;n} \log_n \left(\sqrt[n] n\right)<br />
The first term, {\sqrt[n] n}^{\;n} is n. The second term, \log_n \left(\sqrt[n] n\right) is 1/n. The product of these two terms is one. If the log (base n) of the expression in question is one, the expression itself must be equal to n.
I meant that it was solved using Calculus, I got the solution and I uploaded it.
http://florble.co.uk/files/26341.JPG
http://florble.co.uk/files/8312.JPG
http://florble.co.uk/files/26783.JPG
He solved for a critical point. (aka when y'(x) = 0.) Not y(x) = 0.
One issue with the original question is how to interpret the expression x^{x^3}. Exponentiation is not associative. Regardless of where one puts the parentheses in this expression, the uploaded solution does not solve the equation
x^{x^3}= 3
It finds where the function
f(x) = x^{(x^3)}
reaches a minimum. This function does reach a minimum at x=\exp(-1/3). However, the value of the function at this point is approximately 0.8848, not 3.
The original problem has different solutions depending on interpretation, neither of which is \exp(-1/3).
x^{(x^3)} = 3 \quad\Rightarrow \quad x \approx 1.44225
\left(x^x\right)^3 = 3 \quad\Rightarrow \quad x = \sqrt[3]3
I thin k that x^x^3 is ambiguous. I don't think that x^{x^3} is ambiguous at all; it's x^{(x^3)}.
x^{(x^3)} = 3 is solved by x=\sqrt[3]3=1.44224957\ldots
(x^x)^3 = 3 is solved by x=1.319788817878158965558893060240296\ldots
Yes. Without parentheses, exponentiation is evaluated right to left (or top to bottom). Rationale: (a^b)^c = a^{(b*c)}
I solved both equations (x^{(x^3)}=3 and (x^x)^3 = 3) but pasted the same number in twice. :blushing:
I thought that was the case (since the decimal expansion you posted works for the cube root of 3) but I wanted to clarify for others reading the thread.
CR, thanks for the correction.
One can of course "use calculus" to solve either of the equations x^{x^3} = x^{\left(x^3\right)} = 3 or \left(x^x\right)^3 = x^{3x} = 3. It's called Newton's method. In general, to solve an expression of the form f(x)-a=0, Newton's method starts with an estimate of the solution and refines these estimates via
x_{n+1} = x_n + \frac{a-f(x_n)}{f&#039;(x_n)}
The former expression, x^{x^3} = 3, has an algebraic solution: x=\sqrt[3]3. A numerical estimation technique will yield 1.44224957..., but why bother? The latter expression, \left(x^x\right)^3 = 3, is (most likely) transcendental; solving it numerically is (most likely) the only way to determine a value.
and
I think he meant to write :
\sqrt 2^{\sqrt 2^{\sqrt {2}^2}} = 2
and
\sqrt[3] 3^{\sqrt[3]3^{\sqrt[3]3^{\sqrt[3]{3}^3}}} = 3
No. I meant to write
\left (\sqrt 2 ^{\sqrt 2}\right)^{\sqrt 2} = 2
\left( \left(\sqrt[3]3 ^{\sqrt[3]3}\right)^{\sqrt[3]3}\right)^{\sqrt[3]3} = 3
I left out the parentheses, which are absolutely essential as exponentiation is non-associative.
Ok I see. Yes that is more interesting.
Sound you get instead:
\log_n\Biggl(\underbrace{\sqrt[n] n^{\left(\sqrt[n] n^{\left(\dotsm^{\sqrt[n] n}}\right)}\right)}_{n+1}\Biggr) =<br /> \underbrace{\sqrt[n] n^{\left(\sqrt[n] n^{\left(\dotsm^{\sqrt[n] n}}\right)}\right)}_n\Biggr \,<br /> \log_n\left(\sqrt[n] n \right)<br />
  • #31
No, you put them in but apparently in the wrong spot.
  • #32
probbably he meant to write it sth like this:
\log_n (...(((\sqrt[n]^n)^{\sqrt [n]^n})^{\sqrt [n]^n})^{\sqrt [n]^n}...)^{\sqrt [n]^n} =\sqrt[n]^n \log_n (...(((\sqrt[n]^n)^{\sqrt [n]^n})^{\sqrt [n]^n})^{\sqrt [n]^n}...)=\sqrt [n]^n^{2} \log_n(..((\sqrt[n]^n)^{\sqrt[n]^n})^{\sqrt[n]^n})..)..=...=\sqrt[n]^n^{n}log_n\sqrt[n]^n=n*\frac{1}{n}log_n n=1 and hence:
(...(((\sqrt[n]^n)^{\sqrt [n]^n})^{\sqrt [n]^n})^{\sqrt [n]^n}...)^{\sqrt [n]^n}=n
Does this make any sense??
  • #33
You don't even need logs to show that sense
(x^a)^b=x^(ab)
