Solving |2-x|^2 - 2|2-x| = 15
  • Thread starter Thread starter frozen7
    Modulus
7 replies · 3K views
frozen7
( l 2-x l ^2 ) - 2 l 2-x l = 15
((2-x)^2) = 15 + 2 l 2-x l ------1
((2-x)^2) = -15 - 2 l 2-x l------2
Am I doing correctly?
How did you get 2?
I think that you intended to drop the absolute value signs.
Yes, |2-x|2l= (2-x)2. Either |2-x|= (2- x) (if 2-x>= 0) or |2-x|= -(2-x)
Change the absolute values to parentheses and you will correct.
The correct answer should be -3 and 7
From 1, I get the answer of -1,-3,5,7
Some more, how to do this question actually?
You also made the mistake of flipping the sign of the constant term : you accidentally made 15 into -15.
PS : It might make things easier to first make a substitution, 2-x = y
The way you solve this problem is by using the definition of the modulus function.
[tex]f(x) = |x| = x~,~~if~x \geq 0[/tex]
[tex]f(x) = |x| = -x~,~~if~x < 0[/tex]
Apply this definition to your problem and convert the equation to a pair of equations over two domains, one in which 2-x is negative and the other, where 2-x is non-negative.
The first equation is correct and it is wrong for the second one. So, what should be the second equation?
Thanks.
( ( 2-x ) ^2 ) - 2 l 2-x l = 15-----1
-( ( 2-x ) ^2 ) - 2 l 2-x l = 15----2
Do you mean this?
Divide the above moduli into two parts , one being x>2 and second being x<2 ,
Solve for both separately and then check final value of x you get after solving under x>2 and x<2 , if it satisfies for both categories of x.
BJ
