Solving a Forces Problem: Need Help!
  • Thread starter Thread starter DethRose
    Forces
2 replies · 2K views
DethRose
Forces Problem Please Help!
Ive got a question in this weeks homework that isn't in the text or anything...i think it is a torque problem but am not sure even where to start :confused:
Its a drawing but the question asks
What force will keep the lever from turning about point 0? Given A=45 cm, B=65 cm, the pull is 80 N, and angle is 30 degrees.
The drawing it just a bar with a starting on the left side, 0 being where a and b join, and an angle labled pull at the other end.
please help i have a test in 2 days haha
thanks
in advance :) Answer: The force that will keep the lever from turning about point 0 is the friction force between the lever and the surface it's resting on. The magnitude of this force depends on the coefficient of friction between the two surfaces, which is not given in the question.
Hi there,
I understand that you are struggling with a forces problem in your homework and are not sure where to start. It sounds like this problem involves torque, which is the rotational force applied to an object. To solve this problem, you will need to use the equation for torque, which is torque = force x distance.
First, you will need to identify the point of rotation, which in this case is point 0. Next, you will need to calculate the distance from point 0 to point A and point B, which are given as 45 cm and 65 cm, respectively. Then, you will need to calculate the torque created by the pull, which is 80 N, at a 30 degree angle. To do this, you can use the formula torque = force x distance x sin(angle). Make sure to convert the angle to radians if necessary.
Once you have calculated the torque at both points A and B, you can set them equal to each other since the lever is in equilibrium (not turning). This will give you an equation that you can solve for the missing force. Remember to use the correct units (N for force and cm for distance) in your calculations.
I hope this helps you get started on solving the problem. Don't hesitate to reach out if you need further clarification. Best of luck on your test!
