Solving a Moment Problem: Find the Answer!
  • Thread starter Thread starter June W.
    Moment Statics
The discussion revolves around solving a moment problem in a physics homework context. Participants are examining the calculation of moments using force components and their respective distances from a point of interest, as well as addressing potential errors in the approach and calculations.
  • Homework-related
  • One participant attempts to calculate the moment using the formula M = F*d and expresses confusion over obtaining a different answer than expected.
  • Another participant questions the method of determining the angle theta and suggests considering the signs of the components.
  • A participant explains their method for finding theta using inverse tangent based on the dimensions of a triangle formed in the problem.
  • There is a discussion about whether the moments from the X and Y components can be added together, with one participant suggesting that they produce opposite rotations.
  • Another participant expresses uncertainty about the signs of the components and the direction of rotation, asking for clarification on how to proceed if they cannot be added.
  • One participant proposes a practical experiment to visualize the effects of the force components on rotation.
  • A participant shares their calculations for the perpendicular distance and moment, noting that their result is close to the expected answer but questions the accuracy of their significant figures.
  • There is a suggestion to carry more significant figures in calculations to ensure accuracy when rounding.
Participants express differing views on the addition of moment contributions from force components, with some arguing they cannot be simply summed due to their rotational effects. The discussion remains unresolved regarding the correct approach to calculating the moment and the implications of directionality.
Participants mention potential issues with the accuracy of their calculations, including significant figures and the direction of moments, but do not resolve these concerns. The discussion reflects varying levels of understanding regarding the application of force components in moment calculations.
June W.
There is a copy of the problem in the picture with the graph.
M = F*d, M = Fxr,
F_x = Fcos(theta), F_y = Fsin(theta) where theta is measured off the positive X axis,
I tried splitting the force vector into X and Y components and then multiplying each of those by the perpendicular distance to the corresponding axis. My understanding from in-class examples was that these two values should sum to the moment about the given point. All I know is that I get the wrong answer:
M = 1*30cos(26.57) + 4*30sin(26.57) = 80.51
According to my book, I should get 83.2. Any help is greatly appreciated!
How did you get the angle of 26.57°?
And think about the signs.
M = F*d, M = Fxr,
Two questions:
1. How did you determine the angle theta?
2. Why do you assume that the two parts which you calculated for M must be added together?
Did you check the direction of the moment each component produces about point B?
1. Because the squares are 1x1, I counted the squares and found the triangle to have sides of length 2 and 3. Then I used inverse tangent to sole for theta. (Apparently incorrectly. Now I get theta equal to 33.69 degrees).
2. I assumed they were added together based on an in-class example. I wasn't entirely sure what the example was supposed to be showing, so I may accidentally be solving for a couple. I don't know how to check the direction of the moment produced around B by the individual components.
This angle is correct.
This is where you use your mind's power of visualization. Pretend that instead of seeing F as shown in the diagram, you see the components of F. If you compare the rotation produced by the component Fy about B to the rotation produced by the component Fx about B, you should see that one rotation will be in the opposite direction from the other. Thus, the components cannot be added together. That's why you should decide which direction of rotation is positive and which is negative when starting the problem.
Aren't the X and Y components of F both positive?
I don't understand how they're in opposite directions; they're perpendicular to each other. Once I get the X and Y components of F, if I don't add them, what do I do with them?
I tried to find the perpendicular distance d between the point B and the line of action, but F*d = M didn't give me the right answer either.
That depends on your choice of the coordinate system. Their cross-product with the forces will certainly not have the same sign for both.
Draw the lines going through the forces: one will pass the origin at the "upper left left" side, one at the "lower right" side.
Why don't you cut out a square like what is shown in the diagram and perform an experiment? If you hold the square at point B and tug on it at point A in the direction of each force component individually, does the square want to rotate in the same direction each time?
Show your calculations.
So the vector pointing in the first quadrant no longer means the signs are always positive - I'll have to check the direction of rotation?
The slope of the line of action is m = 2/3. Using the point (1,4), I solved for the equation of the line, which I got to be y = (2/3)x + (10/3).
The slope of d is m_d = -3/2. Because d intersects the origin in this case (I defined point B to be at the origin), the y intercept is zero, and the equation representing the line d is y = (-3/2)x.
The two lines intersect where x (and/or) y are equal, so:
(-3/2)x = (2/3)x + (10/3)
(-13/6)x = (10/3)
x = -1.54
Using one equation to sole for y and the other to check the value,
y = 2.31.
d is equal to ((-1.54)^2 + (2.31)^2)^(1/2) = 2.78, so
M = 2.78 * 30 = 83.4.
This is close to the answer, but the tolerance range for my answer to count as correct is plus or minus one in the 3rd significant digit. I'm not sure at this point if my answer is wrong because I messed up my sig figs somewhere or if it's because my trig is incorrect.
When dealing with moments, always check the direction of rotation.
(-13/6)x = (10/3)
x = -1.54
y = 2.31.
This calculation is OK. If your sig figs need to be accurate to the third digit, you should probably calculate carrying four digits, and then round the final result to three digits.
Also, you should get in the habit of showing the units of the final answer and any intermediate calculations to avoid confusion.
