MHB Solving a Program to Take & Average Unknown Number of User Inputs
  • Thread starter Thread starter smilesofmiles
    Average Program
The discussion centers around modifying a Java program to accept an unspecified number of user inputs and correctly store them in an array. Initially, the program was set up to prompt the user for a fixed number of inputs, leading to issues with outputting zeros instead of the actual numbers. The user sought guidance on how to dynamically fill the array with user inputs while keeping track of the array size. After troubleshooting, the user successfully implemented a solution that allows the program to read a line of input, split it into individual numbers, and convert them into a double array. The final version of the method uses `String.trim()` and `String.split("\\s+")` to handle the input efficiently. The user confirmed that the program now functions as intended, provided the user follows the input instructions correctly.
smilesofmiles
I want to alter my program so it can take an unknown amount of elements (user inputs). I want the program to automatically count the numbers the user is inputting up until they hit enter to the next line. I think I got the program to keep track of this but now my output is a bunch of zeros in place of the user numbers. I don't know how to fill the array with the user numbers as well as keep track of the array size. I have attached a screenshot of the output.
Please let me know if I've been unclear. Any help, direction or hints will be greatly appreciated. I feel like I'm really close to solving this.
Thank you! :-)
Code:
package calcavg;
import java.util.Arrays;
import java.util.Scanner;public class CalcAvg {    public static double [] getArrayNumbers(){
        Scanner input = new Scanner(System.in);
        System.out.println("Please enter 5 to 10 numbers all one line separated by spaces.");
        String lines = input.nextLine();
        String[] strs = lines.split(" ");
        double userNumbers[] = new double[strs.length];
        /* I originally tried this to get the numbers from the user but this asks the user for a number amount to
        set the size of the array which I don't want.
        System.out.println("Please enter amount of numbers to average.");
        int numbers = input.nextInt( );
        double [ ] userNumbers = new double[numbers];
        System.out.println("Please enter five to ten numbers separated by spaces on one line.");
        for (int i = 0; i < userNumbers.length; i++) {
            userNumbers[i] = input.nextInt( );
        return userNumbers;
    public static double calculateAverage(double [ ] userNumbers){
       int counter;
       double userSum = 0;
       for(counter = 0; counter < userNumbers.length; counter++){
            userSum = userSum + userNumbers[counter];
       return (userSum / counter);
    public static void printResults(double [] userNumbers, double average){
       System.out.print("The average of the numbers " + Arrays.toString(userNumbers) + " is ");
       System.out.printf("%.2f", average);
       System.out.print(".");
    public static void main(String[] args){
       double userNumbers[] = getArrayNumbers();
       double average = calculateAverage(userNumbers);
       printResults(userNumbers, average);
Technology news on Phys.org
Never mind, I figured it out. It doesn't stop between 5 and 10 inputs but as long as the user follows the prompt it should be okay.
Code:
       String numbers = input.nextLine();
       String[] strHolder = numbers.trim().split("\\s+");
       double userNumbers[] = new double[strHolder.length];
       for(int counter = 0; counter < strHolder.length; counter++){
           userNumbers[counter] = Double.parseDouble(strHolder[counter]);
       return userNumbers;
Dear Peeps I have posted a few questions about programing on this sectio of the PF forum. I want to ask you veterans how you folks learn program in assembly and about computer architecture for the x86 family. In addition to finish learning C, I am also reading the book From bits to Gates to C and Beyond. In the book, it uses the mini LC3 assembly language. I also have books on assembly programming and computer architecture. The few famous ones i have are Computer Organization and...
I had a Microsoft Technical interview this past Friday, the question I was asked was this : How do you find the middle value for a dataset that is too big to fit in RAM? I was not able to figure this out during the interview, but I have been look in this all weekend and I read something online that said it can be done at O(N) using something called the counting sort histogram algorithm ( I did not learn that in my advanced data structures and algorithms class). I have watched some youtube...
