Solving Bernoulli Problem with Water & Air Density
  • Thread starter Thread starter commelion
    Bernoulli
commelion
hi
i want to check if i have done this the right way as their are two density values given.
i used bernoulli's equation for incompressable fluid flow.
V^2 = 2(p1-p2)/air density = 0.166 meters/s
is it correct to use the air density in this way even though the manamoter is filled with water ? if not how should i address the difference ?
thanks in advance.
If the change in pressure of the gas is much smaller than the absolute pressure of the gas, then the gas may be considered incompressible.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
