Solving Diffraction Patterns: Investigating Central Spot Intensity/Radius
The discussion centers on the diffraction pattern created by blocking monochromatic light with a circular disc and the characteristics of the central bright spot, known as the Poisson spot. The user seeks to understand how the intensity and radius of this spot change as the distance from the disc to the screen (x) varies, particularly how to eliminate the spot by adjusting x. It is noted that traditional analyses using Bessel functions may not apply as x approaches zero, complicating the mathematical approach. The conversation highlights the distinction between Fresnel and Fraunhofer diffraction, with an emphasis on the challenges of deriving an effective solution from first principles. The user expresses frustration with the complexity of the mathematics involved in resolving the issue.
Dan Forth
Hi
hoping someone can help me with this problem. If I block plane monochromatic light (wavelength lambda) with a circular disc of radius r, and then look at the diffraction pattern on a screen placed a distance x behind the disc, I get a bright spot in the centre of the shadow. All well and good. What I want to know is how do the intensity and radius of that central spot vary as a function of x. Specifically I want to know how small I need to make x in order to effectively eliminate the bright spot. Clearly at x=0 there is no bright spot - as x increases I don't know whether the spot appears with increasing radius or increasing intensity (presumably both) but I need to be able to put some numbers into find at what point the spot becomes intolerably bright/large. For anyone interested the reasoning behind my problem is a botched photolith job that I'm trying to do an autopsy on and avoid repeating the same mistakes!
Thanks very much for any help anyone can give,
Dan
Look up a mathematical discussion of Fraunhofer diffraction in a physical optics text (or just poke around the web). That spot is also called the Airy disk. The intensity is described by a Bessel function. Here's a site that describes it a little: http://dustbunny.physics.indiana.edu/~dzierba/P360n/KPAD/Exps/Poisson/poisson.html
Hey Doc
cheers for the reply. Yeah I've been looking through the textbooks (Fresnel diffraction rather than Fraunhoffer I think) but it's not as simple as I'd hoped. The Bessel functions from the standard analysis will never give you the dot disappearing, as the analysis is invalid for x approaching zero (which it's going to have to do.) The classic undergrad approach fails at the first hurdle. I've got a feeling it's going to involve a lot of unpleasant maths starting right from first principles of diffraction (doubtless quickly resulting in an analytically impossible integral) - just wondered/hoped whether anyone out there had already ploughed through this or had a better way in mind!
Oops, you're right. Obviously I haven't looked at this stuff in ages: I was thinking Airy disk (and far-field limits) while you were talking about the Poisson spot from a circular obstruction (a consequence of Fresnel diffraction).
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
