Solving for Ion Mass in Magnetic Field
4 replies · 2K views
thereddevils
An ion of charge 1.6 x 10^(-19) C and Kinetic energy 2.0k eV enters perpendicularly into a uniform magnetic field .The ion performs a circular path of radius 4.3 cm .Determine the mass of the ion if the magnetic field intensity is 0.5 T.
1/2 mv^2 = 2.0 x 10^3
mv^2 = 4.0 x 10^3 ---1
(mv^2)/r=Bev
mv = (0.5)(1.6 x 10^(-19))(0.043)
v = [3.44 x 10^(-21) ]/m ---2
Sub 2 into 1 ,
m{[3.44 x 10^(-21) ]/m }=4.0 x 10^3
Solve for m , i got a very small figure which is wrong .
THe correct answer is 1.84 x 10^(-26) kg
where did i go wrong ?
hi thereddevils! :smile:
don't you have to convert electron-volts into something else?
hi tiny tim ,
what do i hv to convert that too ? I thought electron volt is joules which means enerygy ?
no, a joule is a coulomb volt, not an electron volt …
it's the energy if you move something with a coulomb of charge through one volt …
an electron volt is the energy if you move something with the charge of an electron through one volt …
joules volts coulombs and so on are SI units, but the electron volt isn't (se the PF Library on electric units ) …
an electron has 1.602 10-19 coulombs of charge,
so 1 eV = 1.602 10-19 joules :wink:​
thanks !
