Solving for potential using surface charge density of a sphere
The discussion focuses on calculating the electric field and potential of a charged sphere using surface charge density. The initial formulas presented for electric field strength contain errors, particularly a factor of 2 discrepancy. The correct formula for the electric field at the surface of a conductor in electrostatic equilibrium is E = σ/ε₀, while E = ρ/(2ε₀) applies to an infinite plane with uniform surface charge density. Clarification is sought regarding the appropriate use of these formulas in different contexts. Accurate understanding of these principles is crucial for solving related electrostatic problems.
BuggyWungos
I'm trying to solve for the potential of a charged copper sphere with only radius and electric field strength known. The field lines are directed into the sphere.
Radius of the sphere: 0.2 m
Electric Field Strength at the surface of the sphere: 3800 N/C
Answer = half of my solution's value.
rho = Q/A
Surface area = 4pi(r^2)
Electric Field strength = rho/2(epsilon nought) OR kQ/r^2
Electric potential = kQ/r
surfafce area = 0.502
E = -q/A2(en) = 3800
-q = 3800*(A2(en))
-q = 1.68*10^(-8)
-q = 3.37*10^(-8)
V = kq/r
V = (9.0*10^9)(-3.37*10^(-8))/0.2
V = -1519 V
This is not the correct formula for the electric field at the surface. This is where your mistake of a factor of 2 occurs.
What is the correct electric field strength formula using rho? I understand that E = rho/(epsilon nought) would give the correct answer, but the formula I was given in my textbook was E = 2(pi)k(rho), which would simplify to E = rho/2(epsilon nought). Is the above formula used for another situation?
##E= \dfrac{ \sigma}{2 \varepsilon_0}## gives the field of an infinite plane with uniform surface charge density ##\sigma##. (The symbol ##\rho## is more often used for a volume charge density rather than a surface charge density.)
The field at a point just outside the surface of a conductor in electrostatic equilibrium is ##E=\dfrac{\sigma}{\varepsilon_0}##. This can be derived using Gauss’ law.
Likes BuggyWungos
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
