Solving Inequalities: 0<(2x+1)(x-2) or 0>(2x+1)(x-2)?
  • Thread starter Thread starter deryk
The discussion focuses on solving the inequality (4x-4)/(x+2)< 2x-3, which simplifies to analyzing the product (2x+1)(x-2) under different conditions based on the sign of x+2. Participants confirm the initial steps taken and discuss how to determine the sign of the product by finding its zeros and testing intervals. It is noted that the intervals to consider are based on critical points, including -2, and that checking points within these intervals helps identify where the inequality holds true. The conclusion drawn is that x>2 is a potential solution, but it is pointed out that the interval -2<x<-1/2 also needs to be considered. The conversation emphasizes the importance of interval testing in solving inequalities.
deryk
Im trying to solve (4x-4)/(x+2)< 2x-3
I get it down to 0<(2x+1)(x-2) if x+2>0
0>(2x+1)(x-2) if x+2<0
Are these right so far? I am not sure what to do now with the product being bigger or smaller than 0. Thanks for your time.
Mathematics news on Phys.org
Right so far.
You have products
the sign of a product depends on the sighns of the factors
ab>0
means
a>0 and b>0
or
a>0 and b<0
ab<0
means
a>0 and b<0
or
a<0 and b>0
another way to think about it is (2x+1)(x-2) is a continuos function
find out where the zeros are
call them a and b with a<b
consider the intervals (since -2 is also an important number)
x<-2
-2<x<a
a<x<b
b<x
all the points in one of these intervals satisfy the inequality or none do
so checking one point in each intervals tells you if the whole interval satifies the inequality
thanks lurf lurf .I got x>2. Does anyone know if that's right?
you missed -2<x<-1/2
consider for example x=-1
(4x-4)/(x+2)< 2x-3
(4(-1)-4)/((-1)+2)< 2(-1)-3
(-4-4)/1<-2-3
-8<-5
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
