Solving integral with substitution
20 replies · 3K views
Shannabel
find the integral from 0 to ln2 of (e^x-1)/(e^x+1)
I really didn't know what to do, but the book had a hint suggesting i multiply the numerator and denominator by e^-x and then use an appropriate substitution..
[((e^x)-1)*(e^-x)]/[((e^x)+1)*(e^-x)]
= (1-(e^-x))/(1+(e^-x))
= (1-(e^x))/(1+(e^x))
but now i can't think of an appropriate substitution. help?
How did you get from:
[itex]\frac{1-e^{-x}}{1+e^{-x}}[/itex]
To:
[itex]\frac{1-e^{x}}{1+e^{x}}[/itex]
To:
apparently i just made up my own rules of calculus.. you're right, i can't do that.
so I'm just at
[1-e^(-x)]/[1+e^(-x)]
Hahah I don't know how your book wants you to do it but try splitting it into two integrals.
how can i split that?
Into two fractions - you have addition on top - and then attack them both separately.
HallsofIvy said:
The first thing I would do is divide:
[tex]\frac{e^x- 1}{e^x+ 1}= 1- \frac{2}{e^x+ 1}[/tex]
Then, for the second integral, let [itex]u= e^x+ 1[/itex]
lol... what did you divide by to get that?
and also, if i use u=e^x, then i get du=e^xdx, and i don't have anything to cancel the extra e^x with..?
I'm not sure what multiplying top & bottom by e^-x does for you, but if you multiply top & bottom by e^(-x/2), you'll probably recognize it as the hyperbolic tangent of x/2.
You can use long division to divide them, similar to normal division of numbers. Or you can write it as [tex]\frac{e^x - 1}{e^x + 1} = \frac{e^x + 1 - 2}{e^x + 1} = \frac{e^x + 1}{e^x + 1} - \frac{2}{e^x + 1} = 1 - \frac{2}{e^x + 1}[/tex]
If you want to follow Hall's suggestion, you should multiply the fraction by e-x/e-x and then use a different substitution.
I would follow c.dube's suggestion by splitting the fraction in two [tex]\frac{e^x - 1}{e^x + 1} = \frac{e^x}{e^x + 1} - \frac{1}{e^x + 1}[/tex]The first one has an easy substitution, but you'll want to multiply the second by e-x/e-x before using a substitution.
ookay so i ended up with
ln(e^(x)+1)+ln(e^(-x)+1)... is that right?
ln(e^(x)+1)+ln(e^(-x)+1) between 0 and ln2
= ln((e^x+1)/(e^-x)+1)) between 0 and ln2
= ln ((e^ln2+1)/(e^-ln2+1))-ln((e^0+1)/e^0+1))
= ln(3/-1)-ln(1)
= ln(-3)
.. which is very wrong, obviously.
where did i go wrong?
The two logs are being added, so you need to multiply their arguments and not divide them.
ahhh! of course!
so now i get
ln((e^x+1)*(e^-x+1))
= [ln((e^ln2+1)*(e^-ln2+1))]-[ln(e^0+1)*(e^0+1)]
= ln(-3)-ln(4)
= ln(-3/4)
closer? but still not right...?
e^-ln2 ≠ -2
Make sure you use the rules of logs and exponents correctly when you simplify.
Look at the part [itex]e^{-\ln2}[/itex] and how you could re-express that. Then run with it.
EDIT: Haha as Bohrok said.
Bohrok said:
e^-ln2 ≠ -2
e^-ln2= (1/2)??
bohrok said:
yes! :smile:
got it! :):)
You guys are making this much too difficult! Note that the integrand is tanh(x/2) which is in turn sinh(x/2)/cosh(x/2). Substitute u = sinh(x/2) and recall that the derivative of sinh is cosh. The integrand then becomes 1/u, which integrates to ln(u). Resolve the substitution and voila.
my prof left the part of the course with function like sinh and cosh out of the course this year.
