Solving limits containing trig expressions
PhizKid
\lim_{x\rightarrow \frac{\pi}{2}} \frac{tan(2x)}{x - \frac{\pi}{2}}
I was given a couple of hints: use substitution, and that there isn't any need for the tangent double angle formula.
I would have never thought to use substitution if I tried to solve this all day, and I had been trying to manipulate the tangent double angle formula for like an hour before I was told I didn't need it.
How do you know when to use methods like substitution and when not to use the double angle formulas? Especially when there are like 30 of these on an exam, I can't even solve this 1 problem within an hour and I have to solve 30 in 45 minutes.
Anyway, I got (actually I didn't, since I was told to do all of this and could never have though of any of this on my own):
\lim_{x\rightarrow (x - h)} \frac{sin(2h + \pi)}{h \cdot cos(2h + \pi)} \\<br /> \lim_{x\rightarrow (x - h)} \frac{-sin(2h)}{-h \cdot cos(2h)} \\<br /> \lim_{x\rightarrow (x - h)} \frac{sin(2h)}{h \cdot cos(2h)}
I don't know what I should do now. Should I convert back to tangent? Use double angle formulas? More substitution? Something else? How do you know what exactly to do at this point?
The LaTeX tags are case sensitive - use [ tex ] and [/ tex ] (no spaces), not and.
I fixed it in my post.
You do a bunch of problems and learn what works best in various cases. You'll develop your intuition over time.
Also, you need to understand what the notation means. You need to get the basic stuff like that down otherwise you'll just make learning the rest of the material more difficult.
The denominator goes to 0 in the original problem, so sometimes it helps to rewrite the limit in terms of a variable going to 0. So what you did was let ##h = x-\pi/2##. Then when you rewrite the problem in terms of h, you get
$$\lim_{h\to 0} \frac{\sin 2h}{h\cos 2h}.$$ At this point, look up some of the special limits you should have learned about in class and see if you can see how they might help you in evaluating this one.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
