Solving Logarithmic Equation: Log81x + logx3 = 2
  • Thread starter Thread starter valon92
    Logarithmic
10 replies · 2K views
valon92
The equation is the following:
Log81x + logx3 = 2
I've been bashing my head with change of base but i can't seem to get anywhere with it. 81 is rewritable as 34 which seems like it has something to do with the solution, but i just can't seem to get the hang of it. I always get stuck with logs on both sides of the equation and no way to simplify it further..
Any help?
Thanks
Well the change of base formula is as follows: [tex]log_ab=\frac{log_cb}{log_ca}[/tex] so really you don't even need to use the fact that 81=34, but you can. Use the change of base first and then see where you get.
yup using the change of base i got to: ln x/ln 81 + ln3/lnx = 2 but that's as far as i got. I tried simplifying them, getting a common denominator, bringing onto the other side but seems nothing that i do gets me to a solution
Do you mean after the change of base or through the original?
After the change of base, you'll have a quadratic in u to solve.
And by the way, since [tex]log_ab=c[/tex] is equivalent to [tex]a^c=b[/tex] then [tex]log_{a^n}b=c[/tex] is equivalent to [tex](a^n)^c=b[/tex] or [tex]a^{nc}=b[/tex] so you can change it into [tex]log_ab=nc[/tex]. You can use this for [tex]81=3^4[/tex]
solved it using the quadratic equation and replacing ln x with U after the change of base, thanks for the help!
No problem :smile: And I'd suggest you try learn to solve them without using the change of variable, because this helps you notice when you have a quadratic in some function u=f(x). It will definitely come in handy.
Any suggestions about expanding
(1+ax)^3/2
for 5 non-zero terms?
using pascal's triangle I am gettin horrible exponents while if i rewrite it as (Root of [1+ax])^3 it doesn't look much better as i don't have two clear values to use in the formula :\
uhm, might have solved it: does this look correct?
1+3/2 ax + 3/8 a^2x^2 - 1/16 a^3x^3 + 1/128 a^4x^4
