Solving Newtons Third Law: Mass and Force in Blocks A & B
In the discussion about two blocks, A (1kg) and B (2kg), pushed by a 12N force, participants clarify the application of Newton's Third Law and the relationship between the forces exerted by the blocks on each other. Block A exerts a force on Block B, which must be less than 12N due to the differing masses and the net force acting on the system. The accelerations of both blocks are the same, leading to the conclusion that the force exerted by Block A on Block B can be calculated using the combined mass of both blocks. Ultimately, the correct acceleration for the system is determined to be 4 m/s², allowing for the calculation of the force each block exerts on the other. Understanding these principles simplifies the problem-solving process significantly.
Weave
Two blocks are lined up in a row. Block A a mass of 1kg, and Block B with a mass of 2kg. If block a is A is pushed forward by 12N, how much force does Block B exert on Block A. Friction can be nelected.
Newtons Third law
F(A on B)=-F(B on A)
For the system of A:
F_{Force on A}-F_{B on A}= m_{a}a_{a}
For the system of B:
F_{A on B}=m_{B}a_{b}
I know something is wrong because when I plug in values I get F_{B on A}=0
I think it may be just me but I've had some trouble with Newtons Third law, I can't stand the book we are using: Physics for engineers and scientists by knight, any suggestions?
Weave said:
Newtons Third law
Good.
I'd write that as:
F_{Force on A}+F_{B on A}= m_{a}a_{a}
Good.
Now what can you say about their accelerations?
Well I know that the Acceleration of B is going to be less than A. Since A acts on B's mass of 2kg, B will act on A less than 12N.
Right?
Doc Al said:
Good.
I'd write that as:
But isn't F_{B on A} acting in the other direction to make it -F_{B on A}
Oh really? So you're saying that A will pass through B? :wink:
Since A acts on B with 12N, B will have to act on A less than 12N because there is a Net Force.
12 N is the applied force on A, not the force that A and B exert on each other.
By definition, the force on A due to B is F_{B on A}. So the net force on A will be the applied force (12N) plus the force of B on A.
Let's get specific. Assume A is on the left and B on the right. And let's take to the right as the positive direction. Let's call the magnitude of the force of B on A (and A on B) to be Fn. So F_{B on A} = -Fn, since that force points to the left. And F_{A on B} = +Fn, since that force points to the right.
It's certainly true that F_{B on A} = -F_{A on B}. Make sense?
Got yah on that.
Ok, so by definition. of F_{B on A} = -F_{A on B}
The agent acts on A with 12N, then A must act on the agent with 12N, right(neglecting friction)? The force that A imposes on B:
F_{AonB}=m_{a}a_{acceleration of a}
I get it conceptually, but I guess I have trouble representing it mathematically.
That's true not by definition, but by Newton's 3rd law.
That's certainly true, but we don't really care about what happens to the agent of that force in this problem.
Careful: you mixed up your A's and B's a bit.
Since the only force acting on block B is the force from A, then F_{A on B} is the net force on B. Then F_{A on B} = m_b a_b follows from Newton's 2nd law.
But return to the accelerations for a minute. How does the acceleration of A relate to the acceleration of B? Hint: Use common sense!
The accelerations are going to be the same?
You got it.
So.
Acceleration is going to be a=F/m=12N\_div1Kg=12m/s^2
F_{A on B} = m_b a_b= (2kg)(12m\s^2)=12N
then this equals -F_{B on A} ?
Weave said:
So.
That acceleration is incorrect. When you apply Newton's 2nd law to block A, you must use the net force on block A. You just used the applied force of 12 N.
(Note that you can also treat block A and B together as a single system. What's the net force on that system? What's its mass?)
ok..
F_{AB}=(m_{a}+m_{a})a_{AB}
The force on A in contact with B is 12N so the net force is 12N.
a_{AB}=F_{net}divided(m_{a}+m_{b})=4m/s^2
Yes, that's the correct value for the acceleration of the blocks. Now you can solve for the force they exert on each other.
Thanks Doc...did I really make this problem harder than it really was?
Problems often appear much easier after you've figured them out! :smile:
