Solving Operator Problem with Matrix Representation
  • Level: Undergrad
  • Thread starter Mentz114
    Operator
16 replies · 3K views · last reply
Mentz114
This matrix, I had hoped was a good candidate for (a representation of ) a unitary, self-adjoint operator
\begin{align*}
\hat{A}&= \frac{1}{D} \left[ \begin{array}{cc}
a^2 & iy^2 \\\
-iy^2 & a^2\end{array} \right]
\end{align*}
##a## and ##y## are real with ##D^2=a^2-y^2\ >\ 0## . ##\hat{A}## has determinant ##1##, eigenvalues ##(a-y)/D,\ (a+y)/D## and eigenvectors ##\vec{e}_0=(1,i),\ \vec{e}_1=(1,-i)##. Also ##\hat{A}^{\dagger}=\hat{A}^{T}=adjoint(\hat{A})=\hat{A}^{-1}##.
When the unit vector ##(\cos(\theta),\sin(\theta))## is acted on by ##\hat{A}## its length changes to ##(a^2+y^2)/(a^2-y^2)##. This is unexpected because the determinant of ##\hat{A}=1##.
Is my expectation wrong, or is there some flaw in ##\hat{A}## that I have missed ?
My calculation is that the determinant is
$$\frac{a^2\cdot a^2 - iy^2\cdot(-iy^2)}{D^2}
= \frac{a^4+i^2y^4}{a^2-y^2}
= \frac{a^4-y^4}{a^2-y^2}
= a^2+y^2
which is not necessarily 1 if the only constraints on ##a## and ##y## are that they are real.
First, a terminology issue: I think you want your ##A## to be orthogonal, not unitary. A unitary matrix satisfies ##A^\dagger A = I##. An orthogonal matrix satisfies ##A^T A = I##. They are only the same for real matrices. Unitary matrices preserve ##\psi^\dagger \psi##, while orthogonal matrices satisfy ##\psi^T \psi##.
Second, for your matrix ##A## to be orthogonal, you need ##D = \sqrt{a^4 - y^4}## rather than ##D = \sqrt{a^2 - y^2}##
##A^T A = \frac{1}{D^2} \left( \begin{array} \\ a^4 - y^4 & 0 \\ 0 & a^4 - y^4 \end{array} \right)##
= a^2+y^2
Thanks for that. I can't imagine how I get the wrong determinant. That cures my problem, though.
Thanks, point taken.
I can move on to the next bit now ...
andrewkirk said:
My calculation is that the determinant is ...
stevendaryl said:
First, a terminology issue: I think you want your ##A## to be orthogonal, not unitary. ...
A million aplogies. It is with a very red face that I have to admit to a terrible mess. The matrix is actually
\begin{align*}
a & iy \\\
-iy & a\end{array} \right]
\end{align*}
The other formulae are correct, including ## \hat{A}^{\dagger}=\hat{A}^{T}=adjoint(\hat{A})=\hat{A}^{-1}## and ##\hat{A}^{\dagger}\hat{A}=1##.
So, I'm stuck with an apparently Hermitian matrix with determinant 1 which does not preserve the length of a vector. Ugh.
Are you trying to construct a Hermitian matrix or a unitary matrix? A Hermitian matrix shouldn't be expected to preserve the lengths of vectors. A unitary matrix would.
Mentz114 said:
The other formulae are correct, including ##\hat{A}^{\dagger}=\hat{A}^{T}=adjoint(\hat{A})=\hat{A}^{-1}## and ##\hat{A}^{\dagger}\hat{A}=1##.
I'm not sure I see these. Your matrix ##\hat{A}## in this post is equal to its own conjugate transpose (because conjugating flips the signs of the ##i## factors after transposing them), so ##\hat{A} = \hat{A}^\dagger##. Thus ##\hat{A}^\dagger \hat{A} = \hat{A}^2##, which does not equal the identity matrix (because the off diagonal terms don't cancel).
If you just take the transpose of ##\hat{A}## here (without complex conjugating), then I think you have ##\hat{A}^T \hat{A} = I##, yes. But, as @stevendaryl pointed out, that means ##\hat{A}## is an orthogonal matrix, not a unitary matrix.
Actually, this isn't quite the case either. The determinant of
a & iy \\\
is ##a^2 - y^2##; the square root of that is what should appear as a prefactor in ##\hat{A}## in order for ##\hat{A}^T \hat{A} = \hat{I}## to be true, since if we multiply the above matrix by its transpose we get ##\left(a^2 - y^2 \right) \hat{I}##, i.e., ##D \hat{I}##. In other words, we should have
\begin{align*}
\hat{A}&= \frac{1}{\sqrt{a^2 - y^2}} \left[ \begin{array}{cc}
a & iy \\\
\end{align*}
\begin{align*}
a & iy \\\
\end{align*}
With your ##A##, ##A^\dagger \ne A^T##. The operation ##\dagger## is the complex conjugate of the transpose, not the transpose. The transpose is
##A^T = \frac{1}{D} \left( \begin{array} \\ a & -iy \\ iy & a \end{array} \right)##
Then ##A^\dagger## flips the sign of ##i## to get back to ##A##.
With your adjusted ##A##,
##A \left( \begin{array} \\ cos(\theta) \\ sin(\theta) \end{array} \right)##
##= \frac{1}{D} \left( \begin{array} \\ a\ cos(\theta) + iy\ sin(\theta) \\ a\sin(\theta) -iy\ cos(\theta) \end{array} \right)##
The sum of the squares of the terms gives:
##\frac{1}{D^2} (a^2 cos^2(\theta) +2iya cos(\theta) sin(\theta) - y^2 sin^2(\theta) + a^2 sin^2(\theta)) -2iya cos(\theta) sin(\theta) -y^2 cos^2(\theta)) ##
##= \frac{1}{D^2} (a^2 - y^2)##
So if ##D^2 = (a^2 - y^2)##, the sum of the squares is 1.
Note, that for a matrix ##\left( \begin{array} \\ u \\ v \end{array} \right)##, there is a distinction between: ##u^2 + v^2 = 1## and ##|u|^2 + |v|^2 = 1##. An orthogonal matrix preserves the first, and a unitary matrix preserves the second. Your matrix is not unitary, it is orthogonal.
Right, that clears it up a bit. So the sum of squares ##V\cdot V=(\hat{A}V)\cdot (\hat{A}V)## is preserved but ##(\hat{A}V)^{*}\cdot (\hat{A}V)## is not ?
I now recall that 'length preserving' refers to the inner product ( and the 'O' in 'SO(n)' is for 'Orthogonal').
I thought the sum of the squared amplitudes was the same thing i.e. a length. I'm glad to get that sorted.
I'm answering my own mail because, thanks to @PeterDonis and @stevendaryl I have overcome my difficulties and have a unitary operator. The key thing is that the rows and columns of the operator must be normalised which gives,
\begin{align*}
\hat{A}&= \frac{1}{\sqrt{a^2+y^2}} \left[ \begin{array}{cc}
a & iy \\\
\end{align*}
Now ##\hat{A}\left( \begin{array} \\ \cos(\theta) \\ \sin(\theta) \end{array} \right) =\frac{1}{\sqrt{a^2+y^2}} \pmatrix{i\,\sin\left( \phi\right) \,y+a\,\cos\left( \phi\right) \cr a\,\sin\left( \phi\right) -i\,\cos\left( \phi\right) \,y}=\psi## and clearly ##\psi^*\psi = \frac{(a^2+y^2)(\cos(\theta)^2+\sin(\theta)^2)}{a^2+y^2}= 1##.
So probability is preserved at the cost of losing orthogonality. ##\hat{A}## is its own conjugate transpose which is required for unitarity.
Thanks, StevenDaryl for pointing out that the dagger op has a transpose which solved my problem with evolving density matrices.
Mentz114 said:
A\hat{A} is its own conjugate transpose which is required for unitarity.
No, that's not what's required for unitarity. A matrix is unitary if its conjugate transpose is its inverse, i.e., ##\hat{A}^\dagger \hat{A} = \hat{I}##. Your matrix is its own conjugate transpose, yes, but it's not its own inverse, so it doesn't satisfy the requirement for unitarity. Your matrix is now neither unitary nor orthogonal (it was orthogonal before, with ##1 / \sqrt{a^2 - y^2}## as the prefactor).
It's not enough for a matrix to have determinant ##1## in order to preserve the lengths of all vectors. (It's not necessary either; only the absolute value/complex norm of the determinant has to be ##1##.) In order to preserve the lengths of all vectors a matrix must be unitary, essentially by definition. If a matrix ##U## is unitary then ##\lvert \det(U) \rvert = 1##, but not every matrix with ##\lvert \det(A) \rvert = 1## is unitary.
Simple example: ##A = \begin{bmatrix} \lambda & 0 \\ 0 & \lambda^{-1} \end{bmatrix}## for any ##\lambda \neq 0 \text{ or } \pm 1## has determinant ##1## but isn't unitary.By the way,
\begin{align*}
a & iy \\\
\end{align*}
That's not a unitary matrix unless ##y = 0## or ##a = 0##, in other words if ##A = \pm \mathbb{I}## or ##A = \pm \sigma_{\mathrm{y}}##. You only checked that it preserves the lengths of vectors with real-valued coefficients.
In general, the only ##2 \times 2## Hermitian matrices that are unitary are:
  1. ##\pm \mathbb{I}## where ##\mathbb{I}## is the identity.
  2. Linear combinations ##\boldsymbol{n} \cdot \boldsymbol{\sigma} = n_{\mathrm{x}} \sigma_{\mathrm{x}} + n_{\mathrm{y}} \sigma_{\mathrm{y}} + n_{\mathrm{z}} \sigma_{\mathrm{z}}## of the Pauli matrices with ##\lVert \boldsymbol{n} \rVert = \sqrt{{n_{\mathrm{x}}}^{2} + {n_{\mathrm{y}}}^{2} + {n_{\mathrm{z}}}^{2}} = 1##.
There are no ##2 \times 2## Hermitian unitary matrices other than these.
Unitary matrices don't have to be Hermitian. For example, ##U = \begin{bmatrix} 1 & 0 \\ 0 & i \end{bmatrix}## is unitary but not Hermitian.
More precisely, in order to preserve the complex norms of all vectors in a complex vector space, a matrix must be unitary. To preserve the real norms of vectors in a real vector space, a matrix must be orthogonal.
wle said:
By the way,
Thanks. I found that it does not work for imaginary coefficients like ##(\cos(\phi),\ i\sin(\phi)##. However with density matrices it seems OK.
In view of the disqualifications of ##\hat{A}## is ##\hat{A} \rho {\hat{A}}^{\dagger}## to be considered non-unitary evolution ?
Of course, since ##\hat{A}## is not a unitary matrix.
That's good. Non-unitary evolution is much more interesting !
