Solving Percentages: Remove 9% and Keep Total at 100%
  • Thread starter Thread starter brandozz
    Figure
To remove 9% from a set of percentages while keeping the total at 100%, convert the percentages to decimal fractions. The original percentages of 24.57%, 44.59%, 3.64%, and 18.20% can be expressed as 0.2457, 0.4459, 0.0364, and 0.1820. By dividing each of these decimal values by 0.91, the resulting numbers will proportionally adjust to maintain a total of 1.0. This method ensures that the remaining percentages absorb the removed 9% without equal distribution. The approach effectively recalibrates the values while preserving their relative proportions.
brandozz
Hi all,
I'm a complete math idiot and was wondering if somebody could help me out with an equation that I'm trying to solve.
Lets say I have the following percentages that equal 100%
24.57%
44.59%
3.64%
18.20%
9%
Now let's say I want to remove the 9% but I want the remaining 4 numbers to still equal 100%. How would I distribute the 9% difference? I should also add, I don't want to divide the 9% by 4 and then equal distribute that among the numbers I want them to absorb according to their current percentage. If that makes any sense at all.
Thanks
-Brandon
Mathematics news on Phys.org
brandozz said:
Hi all,
24.57%
44.59%
3.64%
18.20%
9%
Thanks
-Brandon
First off, it's probably simpler to convert all of your numbers to decimal fractions, and get rid of the %. This makes your first four numbers
.2457
.4459
.0364
.1820
Now divide each of these numbers by .91, which will give you a new set of numbers that will add to 1.0. All of the numbers will be proportionally larger than what you started with.
Thanks
Thanks for you help on this!
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
