Solving Problem w/ Norm Space Proof: Advice & Resources
  • Context: MHB
  • Thread starter Thread starter SamJohannes
    Norm Proof Space
The discussion revolves around a problem related to norm spaces, specifically focusing on the 1-norm and its properties. Participants seek advice on how to approach the proof and request resources for better understanding, particularly regarding the continuity of functions defined on normed spaces.
  • Homework-related
  • Sam seeks advice on approaching a problem involving the 1-norm and requests resources for further understanding.
  • Opalg clarifies the definition of the 1-norm and discusses the implications of using different bases for vector representation.
  • Sam expresses confusion about the validity of a specific equality involving the norm and linear combinations of basis vectors.
  • Opalg explains that every vector can be expressed as a linear combination of basis vectors and discusses the application of the triangle inequality in this context.
  • Another participant provides a structured approach to proving continuity in part (b) of the problem, utilizing results from part (a) and defining a relationship between delta and epsilon.
Participants generally agree on the definitions and properties of the 1-norm and the approach to proving continuity, but there is no consensus on the overall solution to the problem as it remains under discussion.
There are unresolved aspects regarding the specific definitions of the norms and bases being used, as well as the continuity proof's dependence on earlier results.
SamJohannes
Hi guys, I've attached a problem that I've been struggling with for a while now. I was wondering if anyone had some advice on how to approach it (in particular part a) or some resources they could recommend to me?Thanks in advance, Sam
Hi Sam, and welcome to MHB!
I assume that $\|\mathbf x\|_1$ is defined as $\sum|x_j|$, where $x_j\ (1\leqslant j\leqslant n)$ are the coordinates of $\mathbf x$ with respect to some basis. It is not clear to me whether that basis is meant to be the given basis $\{\mathbf e_1,\ldots,\mathbf e_n\}$, or the standard basis for $\mathbb{R}^n$?
In the first of those two cases, define $$C = \max_{1\leqslant j\leqslant n}\|\mathbf e_j\|$$. Then $ \|\mathbf x\| = \left\| \sum x_j\mathbf e_j\right\| \leqslant \sum|x_j|\|\mathbf e_j\| \leqslant C\sum|x_j| = C\|\mathbf x\|_1.$ A similar proof will work if the norm $\|\mathbf x\|_1$ is defined with respect to some other basis (such as the standard basis).
Thanks for the response Opalg, it's good to be here.
You're right, ∥x∥1 is the 1-norm.
I don't understand the bit ∥x∥=∥∥∑xjej∥∥. Is this true for all norms? Sorry if the question sounds silly, I'm relatively new to the topic.
-Cheers, Sam
You are told that $\{\mathrm e_1,\ldots,\mathrm e_n\}$ is a basis. So every vector $\mathrm x$ can be (uniquely) written as a linear combination of the basis vectors: $\mathrm x = \sum x_j\mathrm e_j$. Then $\|\mathrm x\| = \left\|\sum x_j\mathrm e_j\right\|$. The next step is to use the triangle inequality to say that this is $\leqslant \sum|x_j|\|\mathrm e_j\|.$
Thanks Opalg. That's helped a lot.
Any thoughts on part b?
Hi Sam,
To prove part (b), fix $\varepsilon > 0$; by continuity of $f$ at $(a,b)$, we can choose a $\delta > 0$ such that for all $(x,y)$, $||(x,y) - (a,b)|| < \delta$ implies $|f(x,y) - f(a,b)| < \varepsilon$.
Here's where I'll use the result of part (a). Let $\eta := \frac{\delta}{C}$, where $C$ is the constant in part (a). For all $x$, $|x - a| < \eta$ implies $||(x,b) - (a,b)||_1 = |x - a| < \eta$. So, $||(x,b) - (a,b)|| < C\eta = \delta$. Hence, $|f_b(x) - f_b(a)| = |f(x,b) - f(a,b)| < \varepsilon$. Since $\varepsilon$ was arbitrary, $f_b$ is continuous at $a$.
  • · Replies 102 ·
10K
  • · Replies 17 ·
10K
